Resetting TPMS w/ Bad iDrive
My Ride: 2005 530i Sedan 6 Speed
Model Year: 2005
Engine: M54
Hello all:
I've got a 2005 E60 530i and had to have a leak patched on one of my tires. The TPMS warning came on before, and is still on after the fix. (Assuming Schwab didn't reset it). I was worried because my iDrive only works intermittently. Is there a way to reset the TPMS without using iDrive on an E60? Any tips are helpful!
Thank you!
Thank you!
My Ride: 2006 BMW 530xi 6MT
Engine: N52
No normal way to reset it without iDrive working.
Possibly there is something in one of the OBD tools to reset it -- not sure.
Engine: N52
There are a couple things I would try for your iDrive. They probably aren't going to fix it, but they aren't hard to do and you might get lucky.
My iDrive would continuously reboot when I had a burned DVD in the Nav drive. That DVD was fine for a long time, but at some point the car just didn't like it. I ejected it and all was fine.
The iDrive CCC unit has a personal computer type fan on the rear. If that fan has died or barely turns, the CCC may just be overheating and that could be your problem.
