reseting auto Gearbox behaviour
2004 545i se auto 75k miles
Just done the gearbox oil change , done according to ZF instructions
Now it snatches on down change from second to first
How do you reset the gearbox learned behaviour to defaults?
thanks
thanks
A bunch of people will probably tell you to do the mythical procedure of holding the accelerator down for 30 seconds with the ignition on but sadly, all that does is fool your car into thinking you have been driving aggressively and any results disappear in about a day. The only real way to do it is within the computer. What your looking for is to have the adaptation values reset the dealer will do it or you can venture into it yourself with a laptop and the right cable. I suggest dealer because there is a software update that addresses this problem and if I remember right it is called the "tip in" update, or something like that.
Thanks for that
Yes , through INPA I reset the adaption and all is well, one very silky gearbox once again
for the record
INPA
F4 E60
Transmission
Gearbox Control module GS19
F6 Activate
F3 Reset adaption values
for the record
INPA
F4 E60
Transmission
F6 Activate
bestofthebest
Mar 28, 2016 02:47 PM
bestofthebest
Jan 5, 2016 07:47 PM
DetailersDomain
Detailing Forum
Sep 22, 2015 03:59 PM
