Removing PDC sensors
Old Aug 10, 2011 | 01:27 PM
sd_dracula's Avatar
going to get some work done on/under the front bumper and was wondering if there is a need to disconnect battery when taking out the PDC sensors?
any persistent errors on the OBC if you don't?
or is it safe enough if you just leave the car off until they are back in?
Old Aug 10, 2011 | 01:33 PM
healthservices's Avatar
I did not run into any code problems, but i also did not start or put my key into the ignition when I pulled my bumper off either.
Old Aug 10, 2011 | 02:16 PM
sd_dracula's Avatar
good to know. thanks. i assume same thing applies to removing fogs.
Old Aug 10, 2011 | 03:00 PM
UltimatePeter
DIY: Do It Yourself
Sep 28, 2015 09:12 AM
UltimatePeter
DIY: Do It Yourself
May 12, 2015 08:00 AM
Zemtem
May 10, 2015 12:13 AM
Adam1v
Apr 5, 2015 11:40 PM
Icy
Jul 16, 2004 11:24 AM
