remove dsc button plate?
My Ride: 520i E60
to remove the dashboard plate where is the dsc button (and other ones depending on car optionals) I need to remove the enthire dash or is possible to "pop out" it from the front with a screwdriver or similar, like on E46?
do you have any pic/topic to suggest me about it?
Yes use a plastic trim tool and start at the passenger/right side of the trim edge. Just pry up and out a little and slowly work it down towards the start button. You can either remove the emergency flasher before or after.
As tonyb635 wrote, you have to remove the wood trim first. Then you put the pry tool on the side of the DVD player and try to release the catch that secures the radio assembly to the dash.
Read this thread from another forum for a pictorial of the process.
Aux-In Retrofit
Aux-In Retrofit
My Ride: 2008 550i M-Sport
There are screws in there to remove and all the panels are hooked in together. You have to start from the top and remove panels one at a time. After the first time it takes about 5-10 min.
chadillac2000
42
09-13-2017 11:15 AM
chadillac2000
DIY: Do It Yourself
04-07-2017 04:31 PM
TexaZ3
05-06-2015 09:54 AM
