rear suspenion
My Ride: my ride 04 530d ,m5 body kit,19"m5 spider rims,,
hi people
looking for some help,had car in for national car test
and it failed on rear suspenion arm,so i changed the arm they said it was
and bingo its still the same so i thought it was the wishbone bottom ball jiont chaned that
still the same problem is when u jack up the wheel it rocks from top to bottom more bottom
pulling my hair out at this stage , whats left of it
well thanks for any help
My Ride: Bmw 530d 2004
It would rock on both directions.
You can also check if it's the wheel bearing by asking someone to press the brake pedal while you shake the wheel. If the backlash disappears when pressing the brake, it's defnitely the wheel bearing.
My Ride: 530I Silver gray with gray leather with Premium Package, Logic 7 Premium sound system with Ipod interface, xenon adaptive headlights, Active steering, Power retractable rear sunshade, Comfort seats, Cold weather package and M5 OEM 166 wheels, Sprintbooster. Ceramic Tint all around, Bilstein Sports shocks with Eibach springs, Brake performance Rotors and Axxis ceramic pads.
+1, If it is the wheel bearing you will have grinding noise when runnning. Plus, if it come to a point that you can rock your wheel at any direction, your wheel along with the axle is bound to come out, very dangerous at this point.
Trinity Autosport
04-26-2015 10:32 AM
