Rear seats creaking sound
Old Jan 24, 2009 | 09:48 AM
Bteljuice's Avatar
whenever i go over a bump or uneven road, i hear some slight creaking noise from the backseat, like some plastic is a bit loose or out of place or uncliped. I cant quite figure out where its coming from, im starting to think its from the rear arm rest thats between the seats that you pull down.
No quite sure, its extremely annoying since im a very picky person.its driving me crazy.
Has anyone encountered this? Surely someone has.
Old Jan 24, 2009 | 09:56 AM
Gene's Avatar
creaks and rattling are a common complaint/issue...you'll see a lot of threads on it..could be anything from a bad shock to a faulty door or window seal.
For me..it was the plastic clips of the rear parcel shelf that connect to the rear defroster unit...the tech had to wrap the clips with the velco to soften the rattle noise...some members have placed some felt material behind their rear seats to get rid of the noise...
GL buddy
***I was able to find/suggest the fix to my problem via searching thru threads here..as always...e60.net came thru and provided the knowledge before the service dept could
Old Jan 24, 2009 | 10:05 AM
Bteljuice's Avatar
Yeah your absolutely right i did a small search but didnt know wht to actually search for LOL
Thx gene
Can you send me the link you checked. Would like to read more bout it.
Thx bro
Old Jan 24, 2009 | 10:09 AM
Gene's Avatar
tech had to take the back seats off..as my seats do not fold either...
honestly..i had that problem back in january...I searched for at least 1-2 hours tho...think i searched under rear seat ratttle or rattle noise
GL man
gene
Old Jan 24, 2009 | 10:13 AM
Gordast's Avatar
I had the same problem and thought it was coming from the seat. Well first there was something loose in the cup holder and the dealer had to glue it in place. Then I figured out when I lower the rear windows just a little the sound is gone. So the dealer replaced the seals. Very quite now.
Old Jan 24, 2009 | 10:26 AM
ADD's Avatar
ADD
The source of the sound could be deceiving too. As you can't be in the back seat and driving, and anyone in the backseat would change the dynamics, and the sound might not be present.
For me, I thought it was the back seat as well, but it turned out to be the plastic backs of the front seats. Mine are the newer articulating backs, (not sure if yours had that then), but where the two pieces overlap each other for the articulation, was the source of the creak over bumps.
GL
Old Jan 24, 2009 | 10:32 AM
Bteljuice's Avatar
oh really, didnt know that the seals make that kind of noise, will try opening the windows and see if its from them.Will also check the plastic cup. thx for tips
Old Jan 24, 2009 | 10:34 AM
Bteljuice's Avatar
GL
I have the old standard seats, dunno if it would come from them, but regardless of that, ill also check that, never know.How did u fix that btw.
Old Jan 24, 2009 | 10:37 AM
Bteljuice's Avatar
btw gene, you joined 10 days before me and yet, look at the posts difference hahaha.
Old Jan 24, 2009 | 10:46 AM
NoName545i's Avatar
My Ride: 2004 BMW 545i Sport Package, Titanium Gray II Metallic, Wheel Style 124
i thought i heard this before
