Rear power window not working.
My Ride: 2006 525xi
Passenger side rear window is not working on my 2006 525xi.At first it was intermittent but now it has gone dead completely.Its stuck at fully closed position and I can't roll down with any switch but i can hear relay clicks but no motor noise.
Scanned with ISTA and found no codes.Then i ran power window test plan to check the functionality of switch and switch is fine because ISTA is registering all the positions of the switch.Other 3 windows are working fine.idrive is also showing "power window anti trap function deactivated".I tried to initialize the reset procedure by ISTA but that specific window is not moving at all. Any ideas please?Thanks
