Rear passenger climate
My Ride: G30 M550i
Model Year: 2018
Originally Posted by solidbmw' post='550005' date='Mar 24 2008, 02:17 PM
Just wondering, the air that blows in the front vent is not as strong as in the back, is yours the same? I have 08, 528i. Thanks in advance.
I didn't know there's one for the rear, I only see the one for the front.
Originally Posted by elyk' post='550018' date='Mar 24 2008, 11:35 AM
it can be adjusted in the idrve - climate section - vent settings
My Ride: G30 M550i
Model Year: 2018
The front center vent, especially during heating, does not blow air with any strong velocity. The heating ducts are low to the floor (since heat rises). Even in the rear, the heat ducts are under the front seats.
I'm pretty sure that the center vent will blow more air under cooling conditions but it's hard to verify things right now since it's cold outside...
My Ride: Current - MY2008 530i comfort access,active steering, HUD, prof nav/TV, bluetootth etc .....
Old - 2006 530i comfort access, active steering, HUD, NAV/TV, Bluetooth
Tired it in warmer climes and the answer is.... when the front center vents are adjusted to max they blow much more air than the back centre vents in cooling mode.
