Rear defrost button causing radio to be staticky..why???
Old Nov 25, 2009 | 10:49 AM
kamilk's Avatar
My Ride: 05 530i
So yesterday my car finally showed the passanger restarint malfunction code so i thought nothing of it because i was just gone get it fixed under the recall..but later that night when i went to use my rear defrost button my radio became staticky all of a sudden but the day before i used it everything was fine so im guessing because my car finally showed the passanger code that its causing the defrost button to interfere with my radio for some reason..i hope the dealer can fix this..anyone have this problem with their car when they got the error message
Old Nov 25, 2009 | 01:05 PM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
There may be a problem with the antenna elements in the rear window or possibly something wrong with the diversity amplifier located above the rear window (behind the headliner.)
Search the forums for a bunch more info!
Old Nov 26, 2009 | 04:03 AM
kamilk's Avatar
My Ride: 05 530i
thanks will look into in now
Old Nov 26, 2009 | 07:36 AM
SmG-Deuce's Avatar
My Ride: 05 545i | sliver grey metallic | SMG trans | sports package | premium | cold weather | HUD | navi | PDC | sunshades | logic 7 | Ipod | MODS - (Mtech v2 angels )(8000k headlights and fogs)( Full Xenon kit) (///M shifter) (LCI u.s spec tails) (285/30/20 & 255/30/20 beyern baroque 3pc rims) 03 FX45 AWD | silver| sports package| premium package| (WIFE) (sold)06 330i | cherry red | sports package| premium | cold weather | logic 7 | Ipod | ( WIFE )
My 06 330 also hav that problem dealer said I hav to remove tint in order for them to check it out.
Also happened after passanger airbag recall
Old Nov 27, 2009 | 03:03 AM
BLooD's Avatar
yup, i had to have a new rear screen to cure this little problem
Old Nov 27, 2009 | 07:27 AM
kamilk's Avatar
My Ride: 05 530i
so i have to take my tints off and it should work again without a problem then after i get the recall fixed
Old Nov 27, 2009 | 07:46 AM
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
If you do have tinting on the rear window, the tint itself may be causing the problem. Either the film itself is interfering with the antenna signals or an antenna element may have been damaged when the tint was installed...
Old Nov 27, 2009 | 12:11 PM
Ian's Avatar
Ian
My Ride: 530D SE
My car had the same problem (as did my previous E39). Had to have the rear window replaced under warranty...
Old Nov 28, 2009 | 06:53 AM
kamilk's Avatar
My Ride: 05 530i
i had the tint for over a year without problems untill the passenger restreint warning came on so i hope its just that because my warrenty expired already and i dont want to pay for a new rear window..well see what happens when i go to open road on monday..thanks for the help
DavaiLave
Aug 2, 2022 02:16 AM
shoryuken15
Apr 9, 2015 03:42 PM
james69z28
Mar 23, 2015 06:45 PM
hakim_radzuan
Mar 12, 2015 02:20 AM
