Rear center vent removal
My Ride: 2004 545i Sport
Somehow someone manage to break the right sidebar the center console air vents in rear. Does anyone know if it can easily be replaced or needs to be taken to a shop...
My Ride: G30 M550i
Model Year: 2018
https://5series.net/forums/topic/380...post__p__46570
(look at the second .pdf posted about removing the rear insert)
Once the rear insert is removed, you may be able to see what you need to do to replace the vent. If not, there are additional instructions in that post that may help you attack it from above or behind...
TexaZ3
05-06-2015 09:54 AM
