Rain sensing wipers
My Ride: 08 535i stock.
wifes car 07 x5 stock
As the title says, my rain sensing wipers do not work. The wipers do though. I have a feeling the winshield was replaced by the previous owner and they tried to reuse the old sensor
Anyway, I do not wish to get a new sensor. I have read that I can disable the rain sensing option with NCSExpert. Doing so would revert the rain sensor to intermitten mode and the sensitivity licker would in then turn into a timer set. I have a laptop set up to do so but have not coded much at all. Basically just put the digital speed on my cluster to work and that's it. Is this a possibility. If so what do I change and in what module should I be looking in.
Another option I have read about is removing the rain sensor fuse and that would put it into default intermittent mode. If this is the easier way to do often I will do this instead of messin with coding. And if this, can someone tell me which fuse it is? I have tried searching but I am still confused with all the mismatched info out there. Thanks to anyone that can help me out.
My Ride: 07 550i Sports Package
https://docs.google.com/spreadsheet/...CNPs2ucN#gid=0
Thanks I've seen that list. It's actually book marked on my computer. But it doesn't say anything about the rain sensors.
There is settings that can be enabled in the idrive for setting the sensitivity of the sensor but rule out the sensor being faulty first.
To reinforce what Jay77 states - BMW manuals state that the rain sensor MUST be reinitialized after changing the windshield. I doubt your glass shop did that unless you had the w/s replaced by a BMW dealer. You can do this with INPA and an OBD II cable yourself.
Cheers,
Gord
Cheers,
Gord
JayArras
05-29-2016 06:35 AM
spediegunz
08-30-2015 09:43 AM
