Radiator coolant resevoir started leaking
Ok, I've hit a snag. The bottom tube doesn't fit quite right, it's a bit big and fluid just leaks out at the bottom. I found a washer like piece still on teh old one, so I placed it on the new one, problem is, while the washer is tight on the old resevoir, it's a bit loose on the new one. Could the bottom tube neck be too small on the new tank? Instead on being done, I'm in worse shape and need to go bacl to the stealer, crap!
My Ride: Metallic gray '05 545i Sport Black Leather with HUD, Step, Nav, PDC, CWP, K&N Air Filter, Black RPI scoop, Black painted calipers, 35% F1 Pinnacle tint, 19" RDSport RS-2F rims with Continental ExtremeContact DWs.
don't forget the cross over pipe if you even look at this pipe wrong it will break!
Attachment 128605
Attachment 128605
HealthServices Thanks to you I fixed the Upper Radiator Hose it broke on me and I was having lots of trouble finding it until I saw the picture you posted up for us. Right away I called the Dealer and picked it up. Thanks for your help my friend Stay UP!
Did you reuse the metal band securing the pipe to the radiator? How did you get it off?
Will
pcy
09-12-2021 06:55 PM
tnixa
05-21-2015 11:01 PM
BigxPx
04-23-2015 10:11 AM
thesalboy
04-08-2015 09:13 AM
