quick question - noise when you open door
My Ride: 545i SE Oct 03 (53 plate) 19" Alpina Classic rims
I hope that this is normal.
I noticed today, that if you leave the car unlocked (no key in ignition) for a while, say 10 mins or so and then you open a door (any door) I am getting a noise that sounds like a vac pump starting - a very brief whirr noise.
whilst messing around with the bluetooth today (new Progman installed) i noticed the same noise, after about the same period of time - the key was in the ignition in pos 1
any ideas... I assume that its normal ??
My Ride: G30 M550i
Model Year: 2018
It's normal. Usually if the car sits with nothing being touched, the car will go to sleep after about 16 minutes. As it goes to sleep, you'll sometimes hear a buzzing noise. Once the car is asleep, if you open a door (or simply unlock it with the remote) the car will wake up and you'll hear buzzing noises again...
DavaiLave
08-02-2022 02:16 AM
