Question on TPM
About every two months, my TPM shows my left rear wheel as needing attention.
All four wheels are maintained at 35psi.
When the warning goes off, my left rear wheel has 30psi. I usually refill it to 35psi.
What could cause a tire leak to be that slow that it takes two months to show a loss of 5psi?
I am very glad that I have the TPM, as I would never be able to discover this small change in tire pressure in one wheel.
Any thoughts?
Any thoughts?
My Ride: 07 BMW 525i Premium Package, Xenon Lighting Package, manual Transmission. Titanium Grey, 20% Tint around the back, 70% V-Kool on front.
Planned mods: Style 71 wheels with Toyo Proxy 4 tires, Sachs suspension upgrade, upgraded stereo, and many more to come.
you must have a nail that's like the size of a hair =P
sorry couldn't be of much help. maybe the valve stem isn't screwed tight enough?
if it bothers you, you can bring it in america/discount tire and they can check it for you for free, but 5psi in 2 months is really nothing tho. my wife has a nail and it lost 20 psi in a week, after it's fixed, it lost maybe 10psi every couple of weeks.
if yours is brand new never been repairs before, then it seems really strange for 5psi in 2 months...
good that you have the TPM, i change my wheels and still haven't put the TPM back in my wheels, once i change the general UHP i will put the TPM sensors back in...
Yeah me too, I struggled w/ low TPM warning for a few months under the impression maybe the valve wasn't tight enough 'cuz the leak was so slow then I took it to the dealer and during visual inspection they found nail punctured at a fixable location but when they removed the tire from the rim to patch it they found another one right on the sidewall and I had to to replace it due to the location.
Thanks. The TPM sensor is really good to pick up these small issues. I have visually inspected the tire, but I could not find anything. You are probably right that there is some type of small puncture in the tire.
It is probably better to get it checked sooner than later to prevent a high speed blow out.
Best regards,
Best regards,
In my case before the head portion of the nail was cut off or some sort and what was left got into the thread and become not visible and of course the one on the sidewall was from the inside corner so neither one of us can see 'till the tire was off the rim... yeah the SA said the one on the sidewall kinda dangerous place to be they can not patch that since it's where its loaded the most aside from the awkward location being in the corner not flat the patch cover in the inside will not stick properly.
Good luck!
Good luck!
My Ride: 04 545 jet black/beige, smg sport,premium,sunshades,logic7,cwp,nav,pdc,bluetooth,16.0,light tint all around,Pirelli PZeroNero
[quote name='monacobmw' date='Oct 8 2007, 01:43 PM' post='479232']
Any thoughts?
[/quote
it could also be caused by cracked rim(hairline fracture would make tire leak that slow) or the tire may not fit tightly on the rim itself-just go to tire shop, they will submerge your wheel in tub filled with water and see where it is leaking from,if it does not bubble(it may not be noticable because you have very slow leak)they will have to dismount the tire and inspect the rim visually,inch by inch...hope it helps,good luck!
Any thoughts?
[/quote
I had a similar issue on my old 1995 E36 M3, the culprit was the chrome finish on the wheels. If the air inside your tires is overly moist, it allows the chrome to start peeling away from the rim and over time the tire loses pressure. The only solution then was to have the wheel re-chromed, it was a hassle, but not as bad as say a blowout at highway speeds? Hope it helps!
Originally Posted by flyingpuck' post='482918' date='Oct 17 2007, 10:23 PM
I had a similar issue on my old 1995 E36 M3, the culprit was the chrome finish on the wheels. If the air inside your tires is overly moist, it allows the chrome to start peeling away from the rim and over time the tire loses pressure. The only solution then was to have the wheel re-chromed, it was a hassle, but not as bad as say a blowout at highway speeds? Hope it helps! ![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
My Ride: 06 530XI Sapphire Black, Black Int. 6sp, Cold, Prem
Good luck!
Good luck!
I've been playing around with tire pressure = I see you run all four at 35psi = You like the ride better than the recommended 30 35??
Thanks
Joe
