Question about rims on an xi
My Ride: black on black 530Xi 6 spd
Hey guys, just a quick question regarding a specific rim setup. I have an 07 e60xi, i'm looking at the MRR gt-7 style, & i was wondering if the xi will accommodate a
19 x 9.5 et 35 all around, i'm pretty sure it will the 8.5 with et 35, just not sure about 9.5, thanks in advance
Dude, sometimes you ask questions that are like
LOL
okay, if it will accommodate 19x8.5 ET35, what do YOU think will happen if you take that same wheel and add an inch of width to it without adjusting the offset to account for the added girth? Think, man! Think!
Get 8.5-9" wides for the front - NO WIDER. And keep in mind that the wider you go, the more you'll have to be sure you get the offsets juuuuust right - wider means you're risking rubbing on the outside AND on the inside of the tire.
Good Luck!
LOLokay, if it will accommodate 19x8.5 ET35, what do YOU think will happen if you take that same wheel and add an inch of width to it without adjusting the offset to account for the added girth? Think, man! Think!
Good Luck!
My Ride: 2006 530xi, 6 speeds manual, Mystic Blue, HID, black interior, premium package, NAV, Bluetooth, heated front seats, Sport steering wheel retrofit, electric shade rear, tinted 35%
Mods: illuminated shifter (innovativcar-tech.de), AC Schnitzer front lip, trunk lip, LED interior & angel eyes MTEC V2.1& RDash License Plate lamps & HID fogs(member brabusw209amg), multifunctional front headrests retrofit (schmiedmann.com)
+ 1 on the above, I'm running style 138 - 7.5 ET43 - 225/50/17 and based own my own measurements I got:
Gap from the tire to the exterior edge of the fender:
- front = 13mm
- back = 38mm
Now the gap between the strut and the tire:
- front = 13mm
- back = 63mm
Again, this is from the edge of the tire and so there is another measurement from the tire to the rim which is 9.5mm in may case (all-season Continentals) so if the tire profile changes (e.g. due to a lower ratio), there may be another gain of 5-7mm on each side.
So basically there is huge room in the back but not as much in the front.
- front = 13mm
- back = 38mm
- front = 13mm
- back = 63mm
You can go 10 in the back
but you have to be very careful lol
no seriously, 10" for the rear... ah, crap... forget it! Just know that you can do it - search through my threads - you'll find all the 4-1-1
sorry to hijack this thread but i would like to get 20's for my 2008 535xi but i was told that is not an easy fitment, 19's would be better. but i like the look of 20's. any suggestions?
I knew at least 2 members here was on 20's on their xi ... but not much style to choose in fact they were custom made probably.
