Question
Old Jun 10, 2007 | 06:38 PM
khooger's Avatar
I can't make up my mind between the MRR GT1-Black with polished lip set with Toyo t1r OR get the OEM 166's with PS2........any thoughts / suggestions here?
Old Jun 10, 2007 | 07:10 PM
vegastrashed's Avatar
If you choose the MMR get 20" wheels. If your only choice is 19" wheels then 166s.
Old Jun 10, 2007 | 07:16 PM
khooger's Avatar
Any additional mod's to fit the 20"....no rubbing?
Old Jun 10, 2007 | 07:23 PM
The correct tire size to get when upsizing to 20" wheels are 245/30/20 and 275/25/20 or 285/25/20. This will keep the rolling diameter the same as the stock 124 wheels. Most people are afraid to use this tire configuration and instead they use 245/35/20 and 275/30/20 or 285/30/20. With this tire configuration you're rolling diameter is 4% and 3.6% bigger, front and back. Depending on what the offsets are on the wheels, you may or may not rub.
Old Jun 10, 2007 | 07:30 PM
khooger's Avatar
Thanks a lot for you assistance....I will check the offset on the wheels.
iNDOLiFE
Bluetooth & Cell Phone Forum
Aug 4, 2015 07:06 PM
e60_simr
Jul 29, 2015 02:35 PM
aqualibrium
Jul 21, 2015 03:11 AM
w84me
Jul 10, 2015 10:56 AM
ST JAMES
Jul 3, 2015 07:04 PM
