Pros and Cons Of Runflats
Old Feb 12, 2005 | 11:49 AM
  #21
JDN's Avatar
JDN
I assume from your specs that was the infamous style 124 wheel that split. I believe you are the third to have the experience if that is the case. I cracked two all the way around.
One of the previous threads on cracked wheels
Old Feb 12, 2005 | 12:07 PM
  #22
pbarch1's Avatar
My RFT did exactly that RAN FLAT. What POS the Dunlop's that came on the car lasted a mer 20,000 miles. besides the fact that they where incredibly noisy, had poor handling characteristics and jittered down the road, wandering all over the place I was still inclined to replace them with another set of RFT's. I spent the last 2 days searching the south land for a set of RFT's No one had them at all. Dunlop's, Bridgestone's, not anywhere to be found. Finally found a set of S03's (GREAT TIRE) apparently the last set in my size in California. So Guys be forewarned if your getting close to needing new tires start looking for them today.
Old Feb 12, 2005 | 04:42 PM
  #23
vern's Avatar
My Ride: 2001 BMW330ci, Steel Gray, Black leather, Steptronic, PP, SP, PDC, Heated seats, Xenon head lights, HK, 6 disk changer, OEM alarm, OEM clears,Iice white fog lights ,Universal trasnciver, 17 inch Michelin Pilot Sport Tires 2005 530i Titanium Gray,Black leather, Nav.,HUD,PP,CWP,SP,PDC,Xenon lights,Steptronic,Logic 7 sound system,,Fold down read seats,Power shades ON ORDER
[snapback]89465[/snapback]
How about Tirerack???
vern
Old Feb 13, 2005 | 08:28 AM
  #24
Rudy's Avatar
My Ride: G30 M550i
Model Year: 2018
Originally Posted by BobS' date='Feb 11 2005, 09:58 AM
Has anyone experienced or heard of endemic problems with runflat sidewalls?? I was just told that I must replace three tires.? In thirty years of driving I've replaced one tire with a sidewall problem, and that was from a curb, not a pothole.? Now I've got three in less than a year.? FYI, tires are Goodyear Eagle runflats on 330xi w/about 25k nearly-all highway miles.
[snapback]89004[/snapback]
I have one sidewall 'bubble' that is showing on one of my Dunlop runflats. I'm sure it was from a pothole -- I can only imagine what my wheel would've looked like if the tire didn't "take one for the team."
Old Feb 13, 2005 | 09:20 AM
  #25
Guest
Guest
Posts: n/a
Originally Posted by Ziering545I' date='Feb 8 2005, 10:33 AM
Asside from the poor ride and noise that most talk about are there any real advantages?
I do notice they take potholes much better than a regular ZR tire
[snapback]87814[/snapback]
The most important advantage is that you can still drive safely after loss of tire pressure. If you have ever had a high speed blowout, you would know that it can be incredibly difficult to maintain control of your car and the run flats essentially eliminate this risk. To improve the safety of its Odyssey minivan, Honda has elected to equip all of the new ones with run flats.
That being said, I have not noticed any "poor ride" or "excessive noise" on my 545i run flats (although I have read many posts to the contrary) -- although I have seen some posts stating that tread life is good (>20,000 mi for a high performance tire). Tirerack indicates the run flat Dunlops are a W rated tire with AA traction grade and A temp grade (a max performance summer tire). Perhaps, I too am lucky that I got a good batch of Dunlops.
Old Feb 13, 2005 | 09:54 AM
  #26
Hormazd's Avatar
Originally Posted by Guest' date='Feb 13 2005, 11:20 AM
[quote name='Ziering545I' date='Feb 8 2005, 10:33 AM']Asside from the poor ride and noise that most talk about are there any real advantages?
[snapback]89725[/snapback]
[/quote]
I don't think you are lucky. I think you have a later batch of Run Flats. I maybe wrong but I am at 8700 miles and have no uneven wear, I think she will go 20,000 without a problem although I will probably change them earlier as i am on a 3 year lease. I hope I am right.
Old Feb 13, 2005 | 10:43 AM
  #27
TitaniumGray5's Avatar
My Ride: '05 545 Sport Week 9
Originally Posted by iDrive535dSport' date='Feb 8 2005, 11:14 AM
As someone who has just had a huge nail pulled out of one I have a couple of other observations.
1. Conflicting information on whether they are repairable: My dealer says yes, if on tread of tyre. Two tyre repair shops say no, this forum seems split; two other tyre places say yes
2. You have no spare, you have a puncture and you need to go on a long journey.
The dealer can't help as he is 40 miles away (and out sources his tyre fitting anyway, plus they don't open on Sundays). You phone a dozen or so tyre places all of whom don't carry this tyre in stock ("we don't get much call for those") all quoting two to three days delivery
3.The first place that says he can repair it needs to hot vulcanize it. That will take him twenty four hours (remember my trip + the ride is really poor on three wheels!). The second will have a go but informs you, "those runflats are a nightmare to get on and off we might scratch the rim"
I put this information forward because it has all happened to me in the last two days, and? I had never given any thought about what I would do in this scenario.
In the end I've found a good tyre place who have the right machine for dealing with runflats, (on and off). They have carried out a good repair IMHO and all for ?10 including valve, balancing and VAT
With only 1400 miles on the clock it's too early to make a judgement, but when it comes time to change I will be considering quality 'normal' tyres and a spare.
Maybe the solution is to all buy an extra tyre and store it- just in case!
[snapback]87870[/snapback]
545 in US has spare tire and runflats.
Old Feb 13, 2005 | 12:25 PM
  #28
Gav530d's Avatar
I had Run flats on my 530D, i've just changed them after 15K for 4 Bridgestone S03 Pole Positions, the improvement in ride is very noticable, but the main improvement is in grip.
My 530D has got 18s on it and Dynamic Drive and with the run flats I found the ride to be very hard and I had very bad traction problems, this could also have been down to 460 lb ft of torque at 2000 rpm, but with the Bridgestone the ride is much smoother with mases of grip.
I have the optional spare in mine plus 2 cans of tyre weld.
Gavin
Old Feb 13, 2005 | 01:40 PM
  #29
evperry's Avatar
Yes I do have that style and I am proud to be number 3.
[snapback]89460[/snapback]
Old Feb 14, 2005 | 01:44 PM
  #30
Guest
Guest
Posts: n/a
Tire Rake did not have the Dunlop's or the Potanza's RFT in stock :'(
ST JAMES
Sep 23, 2015 11:13 PM
DetailersDomain
Detailing Forum
Sep 22, 2015 03:59 PM
ripley
DIY: Do It Yourself
Sep 19, 2015 06:21 PM
benski
F10 Discussion
Sep 16, 2015 07:10 PM
vince_e60
Aug 13, 2015 09:07 AM
