PROGMAN (formerly CIP) 23 at dealers now
I have only posted the most recent portion as te SIB goes all teh way back to CIP 10.xx (in PDF attachment. There my be some enhancements but they are not listed. It will be up to members to report on any GUI interface or menu changes, or other feature enhancements and let us know here.
SI B 61 14 03
General Electrical Systems September 2006
Technical Service
This Service Information bulletin supersedes S.I. B61 14 03 dated June 2006.
designates changes to this revision
SUBJECT
Software Errors Corrected with Progman
MODEL
E60, E61 (5 Series)
E63, E64 (6 Series)
SITUATION
Customer may complain of the following:
The following software errors were corrected with the release of Progman 23.00.00 (Target data Status E060-06-09-520).
CCC: Voice input system incorrectly states speed limit in "km". Refer to SI B84 24 05.
CCC with Top HiFi (SA 677) loses surround sound settings after a Navigation system announcement. Refer to SI B65 08 06.
CCC: The CD/DVD/CDC drive continues to spin even after the key is off. No audio output is heard. When the customer returns to the vehicle the audio CD is on a different track. This is most noticeable while listening to audio books on CD.
CCC: The customer states that sporadically, it is not possible to acknowledge the "Accept" button on the navigation system disclaimer screen using the controller. Refer to SI B84 20 06.
CCC: Radio failure after entering the destination in the Navigation system via the voice input system. Other audio sources are not affected.
CCC: Sporadically the radio continues to play after the key is turned off. This fault occurred after programming the vehicle using Progman V19.1.
CCC: After changing the road map scale using the voice input system; it is not possible to change the map scale using the controller.
CCC: The audible warning gong sounds intermittently after the vehicle is started and cannot be turned off unless the vehicle key is cycled. No check control message is displayed while the gong is sounded.
CCC: The radio audio cuts out briefly in FM mode only while driving. Vehicle already has the tuner profile corrected as per SI B65 26 05 and fault code CCC-ANT "DACA" hardware reset fault is stored.
CCC: The radio station that is currently being listened to intermittently changes to the next station in the station list. This can happen every 2 seconds
CCC: Check control gongs and PDC tones have no audio. Other audio functions operate correctly
Blower motor stays on with key off. Refer to SI B64 01 06.
The speedometer and revolution counter needles shake when the vehicle is idling.
The following software errors were corrected with the release of Progman 22.00.00 (Target data Status E060-06-06-510).
An implausible engine oil level message may be displayed while driving at temperatures below 32?F (0?C). Vehicles produced from 9/2005 with N62TU.
On the CID (Central Information Display) "Service" menu, an "Engine Oil Level" selection is now shown after being the vehicle was programmed with Progman V21.2. Vehicles produced up to 9/2005 with N62. Perform complete vehicle encoding.
Turn signals not working, hazard lights not working, headlights are always on with ignition on, CC message "Light system malfunction" is displayed. The light module is in emergency mode. Vehicles produced up to May 30, 2006.
SI B 61 14 03
Technical Service
SUBJECT
MODEL
E60, E61 (5 Series)
E63, E64 (6 Series)
SITUATION
WOW all are
CCC:
does that mean this only affects all the NAV cars? and non-NAV cars dont experience this?
CCC:
Hummm wonder what this means... Mine Wander + or - about 150 rpms does that count as shake?
My Ride: 2004 530i
Just scheduled for an upgrade, they said it not covered under warrenty unless it needs to be done..so i just listed about 3 things on the list that it fixes...and mentioned that i heard the software upgrade fixes it all. told them to turn off my DRLs and hopefully I can get MP3s to play now...
cobradav,
Is there anything there that says anything about DIESELING sound coming from petrol engines. I have develop a little annoying dieseling sound (it actually sounds like a diesel) when in iddle at time or after coming to a stop. my shop foreman says that CIP 23XX will fix it as he saw it in his computer but i dont see it in your report. Could you check with your resources?
