PROGMAN (formerly CIP) 20.01.00 Bulletin released
New update notice released today
SI B 61 14 03
General Electrical Systems January 2006
Technical Service
This Service Information bulletin supersedes S.I. B61 14 03 dated December 2005.
designates changes to this revision
SUBJECT
MODEL
E60, E61 (5 Series)
E63, E64 (6 Series)
SITUATION
Customer may complain of the following:
The following software errors were corrected with the release of Progman 20.01.00 (Target data Status E060-05-12-510).
While driving, the SMG control module switches to emergency program. SMG Fault Code 5101 (Hex) "Analyze hydraulic sensor" is stored. (E60 M5 only) Refer to SI B23 01 06.
Check Engine Light is on, DME FC "2F4F vehicle speed plausibility" (N62TU only).
The following software errors were corrected with the release of Progman 20.00.00 (Target data Status E060-05-12-500).
Poor Idle quality after a cold start. N62TU engine.
Engine juddering/idle speed surging when it is cold. N52 engine.
Engine pinging under light load. N62TU engine.
After programming the CID (Central Information Display) using Progman V19.x, the CID is blank and fault "A469 Internal Electronics Failure" is stored. Progman 20.00.00 prevents this programming failure. If the fault already exists the CID needs to be replaced.
The following software errors were corrected with the release of CIP 19.02.03 (Target data Status E060-05-09-535).
No software corrections included in this version of CIP
SI B 61 14 03
Technical Service
SUBJECT
MODEL
E60, E61 (5 Series)
E63, E64 (6 Series)
SITUATION
My Ride: 2013 535i (White with Oyster Interior. Premium Package, Navigation, Technology Pacakge, Park Distance Control, and Rear View Camera)
I am picking my car up for CIP upgrade today. Hopefully it's a latest version...
My Ride: 2006 550i Sport Package, Cold Weather Package, Premium Sound Package, Comfort Access, Xenon Headlights, Adaptive Headlight Control, Navigation System, Steptronic Transmission. Silver Gray Metallic with Gray Leather. Added Red rear reflectors. Swapped stock Style 124 wheels and Bridgestone run-flat tires for BMW Style 125 5-Double Spoke wheels, 8" x 19" front, 9.5" x 19" rear with Michelin Pilot Sport PS2 tires, 245/40YR-19 front and 275/30YR-19 rear.
Originally Posted by hmc' post='229522' date='Jan 25 2006, 03:32 PM
It was released yesterday. I had my car updated the day before yesterday and I got v20. I don't need 20.01 anyway.
Originally Posted by JaniK' post='236728' date='Feb 8 2006, 11:19 AM
Hi,
Do you know where can I get CIP 20.01.00, that I can upgrade manually and not by BMW dealer...
Thanks,
Thanks,
Hi,
Thanks,
Thanks,
On the otherhand, for slightly less $$ (free if you have issues covered under warranty) have the dealer do it.
umnitza
09-02-2015 11:28 AM
