Problem with my E60!
Old 10-16-2009, 06:52 PM
z06bigbird's Avatar
Originally Posted by flyingpuck' post='1034377' date='Oct 16 2009, 09:09 PM
How old are your tires?? Could just be a drone from them...or an aftermarket exhaust...or bearings....or a million other things, if the car is under warranty, take it to the dealer and let THEM figure it out! Good luck and keep us posted!
I have an idea. Instead of listening to/reading all the comments here, why not take the car to the dealer. lol
Old 10-16-2009, 07:23 PM
gwf545's Avatar
My Ride: 2015 535D M Sport
Originally Posted by bmw_irl' post='1034025' date='Oct 16 2009, 11:07 AM
Hey guys,
I have a 2008 520d m sport 47,000 and as i was driving down the motorway today i discovered there was a low humming noise from the car everytime i was doing 63 - 67 mph.
Is it a wheel bearing or worse?
Runflats? Dunflops? They start out quiet, then they begin humming and then they roar. Crappy tires to be replaced at the first opportunity.
Old 10-17-2009, 07:47 AM
porsche911targa's Avatar
Have I ever said this? RFTs SUCK!!!!!!
Old 10-17-2009, 01:45 PM
flyingpuck's Avatar
Not in the last 5 minutes!
Old 10-18-2009, 08:10 PM
mnmike's Avatar
My Ride: 545i/6spd
You say it's in the mid 60's, but not at slower or faster speeds?
You can pretty much eliminate a driveshaft carrier bearing or a wheel bearing because they would get louder as you go faster.
A wheel bearing is very noticeable because if you are going around a corner it will either get louder or quieter (depending on which side it's on and which direction your steering).
Do you notice vibration at that speed either in general or through the steering wheel? If you do, I'd say it's likely a wheel balancing issue as a wheel which is not balanced will be noticeable at certain speeds like you mention, but not really faster or slower.
Old 10-19-2009, 10:39 AM
bmw_irl's Avatar
not a bit of play threw the wheel.. booked in to be looked at tomorrow, or as BMW called it.. a test drive..
Old 10-20-2009, 12:17 PM
bmw_irl's Avatar
FL wheel bearing needs replacing
gergnang
02-02-2021 07:29 AM
bbbamboo
09-17-2017 04:33 PM
RussHamel73
06-03-2015 08:24 AM
gaz
05-29-2015 06:11 AM
E60Japanese
03-23-2015 05:23 PM
Quick Reply: Problem with my E60!
