Problem with 2005 545i - again and again
Old 03-24-2010, 06:16 AM
krzyschicago's Avatar
Couple of days ago, I got increased emissions light along with check engine ( this is the 3rd time within last 6 months) and this time the light doesn't want to disappear like it was before after staying on for a day or so. I checked the gas cap but it is firmly attached so this is not it.
I am concerned that something serious might be wrong with the car that because I believe car makes more noise when accelarating and I do not feel "the power" I used to. It is not about ticking tough, just louder engine or something. Any ideas?
Anyway, can someone recommend me reliable and affordable ( comparing to steeler) indy shop or a good BMW mechanic on the northern side of Chicago (suburbs)?
Thanks guys!
Old 03-24-2010, 06:29 AM
TexaZ3's Avatar
Buy the scanner, check the codes, go from there. Without knowing what is wrong with the car, nobody here could give you any meaningful suggestions, except take it to the dealer.
Old 03-24-2010, 06:40 AM
Howitzer's Avatar
What's this scanner you speak of?
Old 03-24-2010, 07:19 AM
billeul's Avatar
How many miles? Checkout my recent post " Dealer experience...."
Old 03-24-2010, 07:23 AM
kscarrol's Avatar
My Ride: E90 M3
Model Year: 2011
You can buy them. Used by the dealer and independent mechanics to read the codes thrown by the car's computer when there is a problem. While we simply see the check engine light on, the scanner will tell what exactly the problem is.
EDIT: Bavarian AutoSport (bavauto.com) has several different models for sale, roughly $150-$180...
Old 03-24-2010, 07:53 AM
It has 63K now.
Old 03-24-2010, 08:01 AM
-Mike-'s Avatar
My Ride: 2008 550i sport
Something that potentially serious
i'd take it to the dealer asap to get a diagnosis
it could be something simple, like perhaps an O2 sensor
why spend 100-200 on a tool that you are likely uncomfortable using
once you know what it is, you can make an informed decision on how to fix
if it is something small, i have a guy i use, but he's by me in the southwest suburbs
Old 03-24-2010, 08:06 AM
luigi524td's Avatar
Thanks guys!
In the USA, if it's an emissions related issue/failure that is covered longer than the 4yr / 50k miles. Read your warranty!!
Old 03-24-2010, 08:09 AM
salaki's Avatar
My Ride: 05 545i 6MT
Go to Costco or local Harbor Freight tools and get OBD2 or OBDII sensor:
http://search.harborfreight.com/cpis...BDII&Submit=Go
Costco has one for $30 I think.
Plug it into your OBDII port to check the P Codes.
The code will give you an idea of what problem you have before handing $100 "diag" fee to dealer.
Old 03-24-2010, 08:18 AM
luigi524td's Avatar
http://search.harbor...OBDII&Submit=Go
Read my prior post about emissions warranty in the USA.
If you want to see for yourself it may not be necessary to but a code reader - Autozone stores will also do a "free" code reading ... but the codes they pull may be too generic for BMWs and I just wouldn't let them "fix" anything!
Quick Reply: Problem with 2005 545i - again and again
