Couple of days ago, I got increased emissions light along with check engine ( this is the 3rd time within last 6 months) and this time the light doesn't want to disappear like it was before after staying on for a day or so. I checked the gas cap but it is firmly attached so this is not it.
I am concerned that something serious might be wrong with the car that because I believe car makes more noise when accelarating and I do not feel "the power" I used to. It is not about ticking tough, just louder engine or something. Any ideas? Anyway, can someone recommend me reliable and affordable ( comparing to steeler) indy shop or a good BMW mechanic on the northern side of Chicago (suburbs)? Thanks guys! |
Buy the scanner, check the codes, go from there. Without knowing what is wrong with the car, nobody here could give you any meaningful suggestions, except take it to the dealer.
What's this scanner you speak of?
How many miles? Checkout my recent post " Dealer experience...."
Originally Posted by Howitzer
(Post 1136991)
EDIT: Bavarian AutoSport (bavauto.com) has several different models for sale, roughly $150-$180... |
Originally Posted by billeul
(Post 1137027)
Something that potentially serious
i'd take it to the dealer asap to get a diagnosis it could be something simple, like perhaps an O2 sensor why spend 100-200 on a tool that you are likely uncomfortable using once you know what it is, you can make an informed decision on how to fix if it is something small, i have a guy i use, but he's by me in the southwest suburbs |
Originally Posted by krzyschicago
(Post 1136976)
Go to Costco or local Harbor Freight tools and get OBD2 or OBDII sensor:
http://search.harborfreight.com/cpis...BDII&Submit=Go Costco has one for $30 I think. Plug it into your OBDII port to check the P Codes. The code will give you an idea of what problem you have before handing $100 "diag" fee to dealer. |
Originally Posted by salaki
(Post 1137070)
http://search.harbor...OBDII&Submit=Go Costco has one for $30 I think. Plug it into your OBDII port to check the P Codes. The code will give you an idea of what problem you have before handing $100 "diag" fee to dealer. If you want to see for yourself it may not be necessary to but a code reader - Autozone stores will also do a "free" code reading ... but the codes they pull may be too generic for BMWs and I just wouldn't let them "fix" anything! |
