pre-LCI to LCI Climate Controls after CIC retrofit ???
Old 04-15-2012, 10:51 PM
balbs's Avatar
My Ride: BMW
For those of you pre-LCI members that have upgraded to the CIC Navigation. I'm sure some of you guys probably installed the LCI climate control unit. Can you guys tell me what works and what doesn't work? The main thing I am concerned about is that I want it to blow cold air if it's hot out or hot air if it's cold out. Also to be able to turn it on and off as well as the ability to control how hard or soft the air comes out.
Old 03-18-2014, 04:59 AM
tusas's Avatar
any info? i am intrested too
Old 03-18-2014, 07:34 AM
Canada22's Avatar
My Ride: 2010 BMW 528XI, 1954 Oldsmobile Super 88 324cui
Model Year: 2010
There's a huge write up on this, it's a little indepth, some wire swapping, new LCI controls, and trim, also needed is the proper trim around the lower bezel (where the ashtray is), and optional is the new navigation wheel.
The climate is controlled through the CIC unit now.
Old 03-18-2014, 08:37 AM
balbs's Avatar
My Ride: BMW
Update...I did the CIC retrofit along with the LCI climate control on 7/2012. I did the pin-21 mod and Patrys (who I bought the retrofit from) I believe programmed my car for the new climate control. While I never really played with the full functions of the climate control before when it was pre-LCI, the new LCI version seem to work okay. I can turn the AC or heater manually off or on, adjust blower volume from bottom, middle and upper vents, etc...
Old 05-29-2021, 03:52 PM
Ardit's Avatar
My Ride: Bmw e60 525d automatic
how fix ac ?
bobbyggx
05-04-2024 12:04 AM
bruce_miranda
04-15-2015 03:25 AM
ranger530i
03-29-2015 04:48 PM
Thomas the Swede
09-07-2003 03:34 AM
08-12-2003 11:41 AM
Quick Reply: pre-LCI to LCI Climate Controls after CIC retrofit ???
