Power Steering Pump leaking?
When changing out my CDV, I notice oil around the Power Steering Pump and surrounding area. The dealer is replacing the Power Steering pump under CPO, but I don't think I've ever heard of the pump itself leaking. Is that common? In the e39 Power Steering fluid was usually leaky from the power steering hose. Anyone ever see a PS pump on a 550 (w/ Active Steering) leak?
Thanks'
Thanks'
My Ride: 2005 545i Sport 6MT
Check your valve cover gaskets first. It is very common for the oil to drip right down on top of the pump. I too at first thought the pump was leaking, but its the valve cover gaskets.
I've gone through 2 pumps...neither due to leaks. the first was replaced because it was noisy, the second because of faulty installation on the replacement...
that pump w/active steering is expensive. be glad its covered under warranty...I sure was.
Thanks'
Thanks'
My Ride: 2006 BMW 550i
i'd check for valve cover leak or similar, like the above poster mentioned.
is the top of the pump wet?
TexaZ3
05-06-2015 09:54 AM
