Possible A/C Problem
Old 07-28-2006, 06:03 AM
  #21
drjochen's Avatar
My Ride: 530i 6 speed
I think it has to do with the humidity. t only happens if it is humid (~ above 60% rel. hum. or so)
Maybe BMW should not do their hot testing in death valley, but in DE over the summer.
Old 07-28-2006, 06:54 AM
  #22
KAF
KAF's Avatar
Model Year: 2015
Engine: N55
There is a fix for freezing of the air con condensors, they were orignally set to cool the air to 1.5C, in humid hot conditions with the A/C running hard this causes ice to form and performance of the A/C goes off.
The fix sets the air to be cooled to 2.4C at which temp the A/C does not ice up.
http://www.alldata.com/tsb/BMW/11334240000...05/6404051.html
Old 07-28-2006, 10:46 AM
  #23
cobradav's Avatar
And here is another related bulletin
SI B 64 02 06
Heating and Air Conditioning June 2006
Technical Service
This Service Information bulletin supersedes S.I. B64 02 06 dated May 2006.
designates changes to this revision
SUBJECT
Water Droplets are Blown from Center Vents with A/C On
MODEL
E60, E61 (5 Series)
E63, E64 (6 Series)
Vehicles produced from October 2, 2005 to December 29, 2005
SITUATION
The customer states when using the air conditioning system on medium to high speed blower, water droplets are blown from the cent vents.
CAUSE
Evaporator drain on housing blocked (manufacturing error, only vehicles produced from October 2, 2005 to December 29, 2005).
Evaporator ices up after a long drive.
Excessive vacuum within the evaporator housing on high blower speed, prevents condensation from draining properly. Caused by faulty drain hose flap.
PROCEDURE
Remove the 2 front side covers of the center console.
Disconnect both evaporator drain hoses at the evaporator housing.
Inspect the drain elbow on the evaporator housing for blockage (a thin plastic membrane will block the drain passage). The depth of the drain port in the elbow is approximately 45 - 50 mm. With a blocked drain the depth of the port is only 20 - 30 mm
If the evaporator drain passage is blocked, use a drill bit (diameter of opening approximately 10 mm) and drill both drain passages out. Clean all plastic shavings from the housing.
If the evaporator drain passage is not blocked, check both evaporator drain hoses for flow by pouring water in each hose. Water should immediately exit from each hose end.
If the evaporator drain passages on the housing are good, refer to SI B64 04 05 for information about possible evaporator icing up which can cause excessive moisture in the air conditioning housing.
Replace both evaporator drain hoses if other measures performed did not repair the vehicle.
If the previous steps do not repair the vehicle, submit a PuMA case to the Electrics Group for further assistance.
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code
Refer to KSD
Labor Operation:
Refer to KSD
Labor Allowance:
Refer to KSD
[ Copyright ? 2006 BMW of North America, LLC ]
Old 08-01-2006, 05:26 AM
  #24
tab545's Avatar
My Ride: #1: 2004 545i; 6-speed manual; Sport Package; Mystic Blue with a gray leather interior and Anthracite wood; CWP; Logic 7. #2: 2010 535xi Touring; Automatic.
My dealer says "Could not replicate." Maybe I'll tell them about the TSB. Thanks.
Old 08-01-2006, 08:09 AM
  #25
Lomag's Avatar
My Ride: BMW
Thanks KAF, I think that SIB would solve my issue. Added onto the list. I'm up to 7 items already, maybe I should schedule my service visit?
Old 08-01-2006, 09:04 AM
  #26
VTbound's Avatar
My Ride: 2005 e60 Titanium grey Auburn premium Sport 6-speed Logic-7 folding rear seats with ski bag Bi-xenon Cold weather package
Originally Posted by Lomag' post='312655' date='Jul 19 2006, 12:17 PM
Yes I thought about that however in my iDrive there's only one setting, I assume it applies it both sides. The passenger side can only adjust the middle and bottom vent air flow rate while the driver side can adjust top, middle, and bottom vent air flow along with that red/blue bar setting. I have that set on one blue bar with the flow rates the same on both sides and all the vents open fully physically. I believe also when you hit MAX it overrides all the iDrive settings. I'm stumped.
You should have the red/blue thing all the way blue in summer. This will make the air coming out of the top vents noticeably cooler. (this is the same adjustment you used to make in the middle of the two center vents on older BMW's)
Old 08-02-2006, 07:57 AM
  #27
BMWNA's Avatar
I'm with BMW of North America, LLC. I've passed this message on to a BMW NA Customer Relations Representative who will be in touch with you soon.
Old 06-11-2007, 07:22 AM
  #28
drjochen's Avatar
Well, it happened to me again lasty Friday (the first hot/humid day here).
I drove ~ 20 min and the AC blower started to go faster ansd faster, but not cold air.
Shut down the entire system for 10 min, suffered, and it worked again. The ice must have melted.
Old 06-11-2007, 07:25 AM
  #29
Lomag's Avatar
My Ride: BMW
Wow you dug up my old thread! I've actually not had this problem since the dealer fixed it. In my case they recharged the A/C system and since then it's colder than ever.
Old 06-11-2007, 07:30 AM
  #30
stanatl's Avatar
I had a problem with my A/C on a hot, humid Atlanta day. Started my car up after it sat at an airport parking lot for 3 days and only hot air came out. The temperature control was set for auto. Trying it in manual didn't do any good. Turned the car off, let it sit for about 5 minutes and re-started and the a/c system worked normally.
My SA said there have been problems with the a/c that were addressed in v. 25.0. I had my car re-programmed recently for this and a few other software related gremlins and no problems since.
Sandrokarton
05-20-2015 05:53 AM
UltimatePeter
DIY: Do It Yourself
05-12-2015 08:00 AM
Skavilla
04-21-2015 03:43 AM
kane1111
04-10-2015 04:40 PM
skidster
29
05-03-2004 09:52 AM
Quick Reply: Possible A/C Problem
