passenger restraint system malfunction
I've recently had a malfunction popup, it's says the passenger restraint system malfunction. I took it to my hookup at the dealer and he said the "mat sensor" or something needed to be replaced. He said the part was like 600 but wanted to get your guys knowledge on this first. Has anyone experienced this before?
try using quotations around your search. good luck
My Ride: E60 530d MSport Auto, 19" 172 Spiders on ContiSports 2's, Pro Nav, Adaptive Xenons, Bruce M's V6 Rear LCI Cables/Lights, Number plate LED
Had the same problem and it was the airbag/seat sensor. Essentially a big flimsy circuit board that gies inside the seat. Part was about £100 from the stealership. Had it fitted and car coded by Indy.
ucsbwsr
26
Feb 26, 2025 08:22 AM
