Passenger AE Doesnt work, LCM Issue?
Old Mar 14, 2022 | 11:09 AM
E60Dre's Avatar
My Ride: BMW 535XI, Almost FBO
Engine: 3.0L N54
Default Passenger AE Doesnt work, LCM Issue?
Hey I have an issue where I only have 1 angel eye working, I bought this car from the last owner and found out theres 2 different types leds, the driver side works but passenger doesnt.
I switched the bulbs and then neither works. My eyebrows work fine and the driver led works when i put it where it was, so could this be a LCM issue?
Im not too familiar with the assembly and dont want to order something till i know what it could be, lux eyes coming soon.
2008 BMW 535xi LCI
Old Mar 14, 2022 | 11:45 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Internal headlight wiring. You should be getting a message on iDrive
Old Mar 17, 2022 | 07:11 AM
E60Dre's Avatar
Engine: 3.0L N54
Yeah I get adaptive headlight malfunction, i figured it would be cause the lights out. Can you explain more on the wiring like the Leds or something i should take to a shop.
Old Mar 17, 2022 | 12:10 PM
Remove the headlight assembly and take the cover off the back. Look at the wiring and it should be cracking with wires touching each other which causes it to ground out. You either tape it back up or you can purchase new assemblies. It's up to you. No one will work on the assemblies they just replace them. Too make sure that's what it is remove it and look inside.
Old Mar 17, 2022 | 02:57 PM
donpb's Avatar
My Ride: '06 530i N52
I kept getting bulb out error, replaced the bulb, but still no go. I opened up the headlight assembly and discovered a mess of bare wires. I covered them with spiral wrap. That rook care of it.
Old Mar 20, 2022 | 07:55 PM
Flguy76's Avatar
My Ride: 2004 BMW 530i, 2010 535, 2010 535xi
get liquid black tape worked perfectly on mine same issue as u have. BMW use recycled material on the wire shrouded didn't work out very well trust me yellow can liquid black tape just separate the wires they will crumbled even mote then brush it on let it dry and your gtg
Old Mar 20, 2022 | 08:03 PM
Flguy76's Avatar
Default Is the lm1 or lm2 module? Ty
ThePilekMan
Mar 14, 2021 04:50 PM
jrolyat129@gmail.com
Jul 9, 2017 06:49 PM
eondi66
Apr 23, 2016 09:53 AM
justalilbit
Apr 28, 2015 05:36 PM
philsmd
Feb 22, 2014 01:44 PM
