Particle Filter Failure ???
Old Dec 30, 2011 | 10:12 AM
Declan Dublin's Avatar
problem came back . Not good and annoying me
anyhow i am bring my car to my local mechanic who is great and has auto logic so hopefully he can sort the problem.
Thanks for the help and advice
Old Dec 30, 2011 | 10:22 AM
sanjsanj's Avatar
My Ride: E60 530d
Originally Posted by Dandle
Check the coolant temps on your engine. It will be interesting to see if your cars running cold.
+1
Old Dec 30, 2011 | 10:41 AM
Anzafin's Avatar
My Ride: Bmw 530d 2004
According to a RealOEM, your car has a combined catalytic converter/diesel particulate filter, unfortunately. It is more laborious to remove/reinstall than the older one, which locates under the car easily accessible, but yours locates right behind the turbo. So, when it comes to a point that the tin can has to be removed/changed/washed/modified what so ever, it will be more time consuming. However, the DPF part of it can be drilled through to get some more lifetime.
It would be a good thing if your mechanic could send the "forced regeneration" command to ECU with his diagnosing software. Even if he could, it can be that the filter is too clogged and the regeneration won't start. Also, the engine coolant temps have to still climb up over 75°C and the exhaust gases temperature have to go over 240°C, even with the forced regeneration.
I suggest you use the "hidden menu" in the instrument cluster to monitor your coolant temps. Here's a guide to open and use that menu: http://www.scoopz.com/m5board/E60_Hi...structions.pdf
- Antti -
Old Dec 31, 2011 | 05:02 AM
- Antti -
Thanks Antti. Will keep you posted
Old Jan 6, 2012 | 07:36 AM
Hi All
Error gone Thank god. Brought to my local mechanic (Dave Breach motors) and he used Auto Logic to run a series of test on the car, excuse my lack of knowlege here but when he plugged in to the car, the car seemed to run a series of high rev tests itself and my problem was a sensor, all cleard up any my car is running superbly .
Thanks for the help all.
Dec
Old Jan 6, 2012 | 09:00 AM
KAF's Avatar
KAF
Model Year: 2015
Engine: N55
Great news, congrats.
Old Jan 6, 2012 | 10:29 AM
Anzafin's Avatar
That's great to hear! Happy motoring!
- Antti -
Old Jan 11, 2012 | 04:19 AM
Liam's Avatar
Not such good news for me unfortunately: DPF is shot; forced regeneration did not work... :thumbsdown:
Will need to clean or replace... Stealer quoted me 1.680? ex VAT...
Old Jan 11, 2012 | 04:40 AM
Anzafin's Avatar
And you are sure that coolant temps rise high enough and you have enough fuel in tank (10l if I remember correctly)?
If you have the separate dpf in the middle of the exhaust piping, under the car, you definitely want to try washing before buying a new one. It is an easy job once you get the dpf removed.
And even if you have the combined dpf/catalysator, I would still recommend it. It is just a bit more difficult remove/reinstall.
- Antti -
Old Jan 13, 2012 | 03:56 AM
Liam's Avatar
Final diagnosis: main turbo failure caused DPF to be blocked beyond any regeneration... Both parts need replacing at the very "interesting" cost of 4.500?
In Holland they say BMW means "Blijf Maar Werken" (Keep On Working) - as in to pay the repair bills... :thumbsdown:
