Parking Light's Flash, Ignition on Question
Old Nov 16, 2013 | 09:50 AM
FXFU's Avatar
My Ride: 530d 292bhp
Question Parking Light's Flash, Ignition on Question
I have only just noticed that when I turn on my ignition the side lights (round rings) start flashing fast in a sequence like a police cars blue's n two's, then a Mexican wave. I'm on an 04 with H7 lighting although I've changed the side lights to led's.
My question is; is this normal and if so why?
Old Nov 18, 2013 | 03:28 AM
pcy's Avatar
pcy
Flashing of those lights is because those bulbs are changed to LED type. Self-checking is done when the key is inserted in to ignition and turned to position 2 or engine started. The resistance on the LED bulbs is not same as the original bulbs; hence, that flickering.
That flashing will go away if you put the original bulbs back on the car, Or you need to buy the bulbs that say "error-free".
Old Nov 18, 2013 | 11:30 AM
gcvt's Avatar
My Ride: 2008 550i - Sport Package, Sport Transmission, Active Steering, Navigation, Comfort Access, 7 Logic Stereo
My LED side markers do this too. It's normal.
Old Nov 18, 2013 | 04:34 PM
KyleB's Avatar
My Ride: 530i
Engine: M54
Mine do it too, every time I start the car. They function just fine when driving. I wouldn't worry about it at all.
Old Nov 19, 2013 | 05:01 AM
svre46's Avatar
My Ride: 545i
Pretty sure you can code out bulb check with NCS Expert or as others stated "error free" bulbs and or load resistors.
Old Nov 19, 2013 | 05:19 PM
FXFU's Avatar
Thanks Guy's, yep it's the led's. Quite cool thought
Tsoup
15
Dec 20, 2021 11:14 AM
Seahawkin03
Sep 26, 2015 11:49 AM
CertifiedOfficial
Apr 13, 2015 08:24 AM
thesalboy
Apr 8, 2015 09:13 AM
