P0368: Camshaft Position Sensor "B" Circuit High Input (Bank 1
P0368: Camshaft Position Sensor "B" Circuit High Input (Bank 1)
I assume it is on the pass side (left hand drive)
But there are three sensors back there. Which is which?
Thanks
Thanks
My Ride: 2006 530i with sport and premium package.
Having a similar issue. Getting a p1017 valvetronic eccentric valve sensor located on the eccentric cam. Are you planning on tackling the job yourself. I'm also gettin p1030 valvetronic monitoring sluggish movement. Anyone have any input if its the valvetronic motor or the eccentric sensor itself. Currently car will start then stall right away.
My Ride: 2004 545i Sport
1998 M3
Bank 1 is the passenger side, sensor B is the exhaust cam position sensor. It will be the sensor closest to the exhaust ports at the rear of the valve cover. The VVT sensor is the uppermost sensor, and the intake cam position sensor is between the two. In the attached picture, the sensors are all removed, and this is for bank 2, but the hole at the bottom is where the exhaust cam sensor is located.
True that! BTW, that leak which I thought was comnig from the vacuum pump seals turned out to be from the oil pressure sensor. I put my hand behind the pump and felt around and voila! Oil present on the plug from the switch. I had my indy guy swap it a while ago but I guess it didn't happen or it wasn't torqued properly. This is why we gotta do everything ourselves to make sure stuff actally gets done! Would you happen to have a deep socket for that switch? I don't have anything that big. LMK.
socale39
09-05-2023 08:30 AM
spitfire23
05-12-2015 04:23 AM
