overheatng problem
Old Nov 22, 2013 | 07:10 AM
LudiBoris's Avatar
Default overheatng problem
hello fellow members i recently had my engine overheat so i changed water pump and thermostat and after i finished everything, i started my car up and and let it warm up and the same problem again overheating msgs yellow and red and fan just going crazy..... what else do i need to do to fix it....... please help, thanks
Old Nov 22, 2013 | 07:14 AM
E60I's Avatar
My Ride: 2006 BMW 530I
Model Year: 530i
Did you bleed the system?
Old Nov 22, 2013 | 07:24 AM
KyleB's Avatar
My Ride: 530i
Engine: M54
year/make/model will help
Old Nov 22, 2013 | 08:10 AM
LudiBoris's Avatar
sorry i forgot to put the year and model i was in a rush
it is a 2006 bmw 525xi
well the mechanic said he did it....
what is the proper process of doing it so i can re check if it was done?
Old Nov 22, 2013 | 12:49 PM
pcy's Avatar
pcy
I am assuming your mechanic connected the electrical connector to the water pump and thermostat.
Bleeding process -
Insert the key in ignition, turn to position 2 (don't start the engine), set the temp to highest setting, press auto, turn the fan to lowest setting. Then press and hold the accelerator pedal for 10 seconds. You will hear the pump start and coolant flows thru the hoses. The pump will run for about 10 minutes.
If your battery is weak, connect the charger to the car before you do the above.
Old Nov 23, 2013 | 03:45 AM
tonyb635's Avatar
You can also have a bad sensor(s) causing your car to think it is overheating when it's actually not... A good friend of mine actually had this problem and during the process there was at least one sensor i believe on the radiator maybe two. I understood him to say that the sensor was failed and telling the car it was overheated when it was actually cold so the fan was put in to high mode.
Old Nov 23, 2013 | 05:00 AM
pcy's Avatar
pcy
As Tony suggested above, bad coolant temp sensor can cause problem.
On N52 engine, the coolant temp sensor is located on the lower radiator hose. Very easy to disconnect the connector and pull out the coolant temp sensor.
When you pull out the coolant temp sensor, coolant will come out of that hole. So, have a new coolant temp sensor (make sure there is a new o-ring on that sensor) ready when you pull out the old one.
Old Nov 25, 2013 | 10:18 AM
LudiBoris's Avatar
i am havin trouble with bleeding my car, i called my local bmw dealership and they said that i cant bleed out my coolant because my pump is electric and it requires a computer to do it. is this true? cuz i seen on youtube lot of people doing it. i have not checked out the sensors yet.
Old Nov 25, 2013 | 10:48 AM
tonyb635's Avatar
Try this the DBond put out.
Old Nov 25, 2013 | 11:00 AM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Here is the Bentley manual page that says how to do it (without the computer):
gergnang
Feb 2, 2021 07:29 AM
bbbamboo
Sep 17, 2017 04:33 PM
RussHamel73
Jun 3, 2015 08:24 AM
gaz
May 29, 2015 06:11 AM
E60Japanese
Mar 23, 2015 05:23 PM
