overheated but not sure
Old Aug 14, 2010 | 02:26 PM
sndohio's Avatar
My Ride: 04 545i 6 speed 92 535i 5 speed 88 325i auto
week ago i got twice warning message , engine is overheated so i turned the engine off and checked under the hood, coolant was full, everything seems to be good. I started the car and there is no more warning light or anything, what can be wrong ??
Old Aug 14, 2010 | 02:29 PM
healthservices's Avatar
check to see that your fans cycle on and off.
Old Aug 14, 2010 | 02:48 PM
sndohio's Avatar
yeah i checked and it was on at that time
Old Aug 14, 2010 | 02:58 PM
does it cycle off or does it stay on?
Do this with the ac off.
Old Aug 14, 2010 | 03:18 PM
sndohio's Avatar
it does stay on with a/c on, but I'll try tomorrow w/o a/c
Old Aug 25, 2010 | 06:05 AM
txag_530i's Avatar
I have had the exact same thing happen to my car for the last two days. It only happens in the morning, on the way home from work after the car sits for ~8 hours I get no warnings or alarms as I drive home. Were you able to determine the cause of the error? I'm thinking that may be the engine coolant temperature sensor is faulty, or may be the thermostat isn't opening up in the morning.
Old Aug 25, 2010 | 09:23 AM
aresh's Avatar
if the fan is working then your best bet is thermostat sticking. BTW make sure the fan is Working when you get that message, as my fan would work only until it got really hot, then it would shut off causing engine to overheat.
Old Aug 26, 2010 | 12:16 PM
txag_530i's Avatar
The SA just called and I'm getting the water pump replaced. Thank goodness for the CPO warranty! The w/p has a price of $500 + additional parts + labor.
I never would have guessed that it was the water pump. I guess by restarting the car the pump was tricked into starting.
DJ JoeyG
Nov 9, 2015 07:24 AM
Henry Peters
Sep 25, 2015 10:15 AM
DAVE H
Jul 6, 2015 12:27 PM
skunkd
E60 M5 Discussion
15
Jan 28, 2010 08:08 AM
ProEx1
Sep 11, 2005 11:37 AM
