Optimum Tire Pressure
I just installed the new Hankook Ventus v12 245/45/17 on my 525i and wanted to inquire if anyone with those tires might recommend an Optimum Tire pressure for best performance. The tire mentions max 50 PSI i have currently 38 psi all around. Thanks !
My Ride: 07 550i Titanium Silver, Black Dakota Leather, Steptronic, Sport, Premium, Nav, Sat. Radio, Logic 7, Comfort Access, Rear Sunshade.
It all depends on the type of driving you are doing. For normal driving, the BMW recommended tire pressures should suffice. If you're doing a lot of hard cornering, then you should increase the pressure in the fronts to at least 40 PSI.
