Oil pan gasket replacement
Old Mar 30, 2025 | 12:10 PM
fast's Avatar
My Ride: White/Tan, Nav, comfort seats, sport steering wheels, sport suspension, active steering, rear window shades, rear shade, heated seats
Model Year: '07-530i
Default Oil pan gasket replacement
So is there anything else I need to do while the subframe is down, like the motor mounts etc
The car is 2007 with 70K miles
Thanks
Old Mar 30, 2025 | 12:17 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Definitely the motor mounts since frame is down. You can still install without it down but easier with it down.
Old May 2, 2025 | 06:16 PM
fast's Avatar
So it all started with a slight engine leak, thought it was Valve cover--- replaced but the leak continued so ended up replacing the oil pan gasket/motor mounts/hood shocks/new spark plugs --- all done
Needs new tires now and good for a while-- IA
Old May 3, 2025 | 01:01 AM
That's great you got it all done. You probably should change your name to slow because you took your time with the project. 😂 j/k Glad everything's done. I need to do mine but I'll get rid of it before I drop mine again.
AbyssalCreation
Jan 29, 2025 06:11 PM
nickpaesler
Feb 1, 2023 06:09 PM
BraveHelios
Aug 19, 2017 10:41 AM
Justcosmo
Jan 25, 2017 07:55 PM
Margal
May 6, 2015 10:15 AM
