Oil Level on dipstick
My Ride: 520d m sport black, leather beige interior
Ok so last November I took my car to dealership for fluid changes/flushes. I know that I had checked the oil level when i got it back..... but I cant seem to remember at what level is was at. Now this afternoon i decided to check the level again, and to my surprise the dipstick marks around 1cm above the max marker. Should I be concerned? Oil level was checked when car had settled for around 2 hours.
Also is it possible for oil colour to be very dark black in colour? Isnt synthetic oil that has been recently replaced have a 'golden' colour to it?
My Ride: 2009 535D M Sport Carbon Black, 172s, Boot spoiler, Tinted Glass, Media pack, Visabilty Pack, Hifi Upgrade, Electric memory heated Seats, Heated steering Wheel, Sport auto Trans,
It's not good to have to much oil as it can put stress on oil seals and gaskets. If it has got to much oil in you need to drain some out!
Model Year: 2010
After normal driving, shut off engine and check engine oil level after about a minute or two. This is the correct way to check engine oil level. For example: driver checking oil when refueling, oil change technician checking oil level after starting engine for leak check then turning off engine. Try a "warm" engine oil level check. It should be lower than a "cold" engine oil level.
And, after doing all the above, wipe the dipstick and re-insert to get an accurate reading. Never just pull it out and look at the accumulated reading.
My Ride: '06 530i M Sport N52
too much oil is potentially more damaging than too little. get car to full running temp, shut off engine and measure after 5 mins or so on a level surface. if it still reads 1cm above max you will need to drain some. any good workshop will have the equipment to suck it out and get the level right. do it very soon.
also all if you have a 525d ( assuming from your handle ) don't worry about the black oil, all diesels do this - even right after an oil change your oil will be black, it's okay.
btw do not all e60's measure oil level through idrive??
