Oil Leaking From My 2007 530i
My Ride: On Order as of May 6- 2007 530i Titanium Grey and Grey Leather, with Sport Package, Premium Pkg, Cold Pkg.
2006 Porsche Boxster
Hello all.. I noticed a puddle of oil under my ride. It was in the garage and then I noticed drips from the plates under the car. It also is VERY clear in color. It does not seem to be engine oil. Could it be transmission oil? The oil level is normal BUT I did notice that the car seemed very sluggish on acceleration today.
Again my thought is transmission oil but what other parts have oil? Again it is clear to the touch.
Thanks!
Regards,
Nick
Thanks!
Regards,
Nick
Was it cool enough that your AC was running? Might have been high humidity (not high temp) causing it to run - in that case it might be condensate (normal) puddling under the car.
Did you detect any odor from the fluid? Most like oil, transmission oil, gasoline, coolant have distinct smells. If none, then it may be water as noted above.
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
Thanks!
Regards,
Nick
Thanks!
Regards,
Nick
My Ride: 2006 525XI, Jet black on Dakota beige. Premium and winter packages. I consider myself a purist and intend to keep my car absolutely stock and shiny.
2008 328I Convertible, Sapphire black on beige interior. Premium package, NAV, iPod adapter.
Retired: 2002 325I, Titanium silver on black leather. Premium package. Absolutely stock and proud of it.
Could also be coming from one of your struts. Just happened to me recently.
My Ride: 2004 530i
premium package/active steering/auto sunshade/tiag/black dakota leather/logic 7
35% tint all around
19' DPE GT7
crawl underneath and check the drain plug for the tranny, I had a small leak that came from the drain plug not being quite tight enough.
Originally Posted by nickolas_g' post='1066128' date='Dec 1 2009, 11:54 PM
My first thought was that it was the A/C, but I noticed that after a number of hours and all day it did not evaporate. That made me question what it was . Rubbed my finger through the puddle in the garage and the new puddle in the driveway and it was surely oily. No real odor. Just confused as to how clear it was, but it was oil.
We shouldn't expect this sort of mechanical problems (except where damage is evident) in our cars - or for that matter, even run-of-mill basic transportation.
My Ride: 530i 2006 model w/ Nav
Please follow my thread here on this site......my case is surely not the norm but I had similar leaks. It ended up being a head gasket b/c of loose screws in the connection of the aluminum part of the engine that is connected to the magnesium part of the engine. I had screws that were missing and had a BMW NA rep tell me that these screws could lead to an engine leak via a bad head gasket. Mine is a worst case scenario but also a realistic cause.
I think you may have a crack in your transmission pan (I assume you have an auto). This happened to my 545i around 60,000 miles and was fixed with CPO. If you can, jack your car up and remove the plastic shield. Shine a bright light around the perimeter of the tranny pan and look for a slow leak around the bolt holes.
Good Luck.
Good Luck.
My Ride: 2006 530i Jet Black over Beige Dakota Leather/Premium pkg/Cold Weather pkg/Steptronic/Xenons/Folding rear seats w/ Ski bag
Retired- 1973 2002 Inka Orange over Black/Dual Weber 40 DCOE Side Draft Carbs/Ansa Exhaust/VDO Gauges
I had a problem that sounds like that, and it was a hairline crack in the transmission pan like Gleckie described, but my fluid was not clear. Apparently it is a common problem/failure? Anyway, covered under CPO. Good Luck.
