Oil leak
Hello all,
Today I saw some oil on my garage floor. It seems to come from the front of the engine compartment. By looking between the radiator and the engine from above, I can see some oil at the bottom. What are the potential sources of leak around that area?
Thanks!
2008 535xi
Thanks!
2008 535xi
Only way to be sure is to remove the bottom splash guard and look for source of leak. First identify the fluid that's leaking - engine oil, power steering fluid, trans fluid, brake fluid, etc.
Usual suspects are oil filler cap may not be tight, oil drain plug may not have been tightened properly, valve cover gasket leak, oil filter cap leak, oil filter housing gasket leak, lower pan gasket leak, etc.
Take some pictures and post here...
My Ride: See signature
I, too recently noticed a little bit of oil on the garage floor plus my Service Engine Soon light has been lit. $2100.00 dollars later.......
Thanks for your input!
Finally, the leak comes from the engine oil cooler.
