Oil Change after Break-in period.
#21
Originally Posted by Guest' date='Apr 5 2005, 04:31 PM
If you have money as well as a car to burn then by all means wait until a year or 15k for the initial oil change. ![Whistling](https://5series.net/forums/images/smilies/imported/whistling.gif)
[snapback]111646[/snapback]
#22
My Ride: F02 LCI Individual
Model Year: 2013
Originally Posted by paasan' date='Apr 6 2005, 12:16 AM
I changed oil after the break-in and prior to driving 8000 km across Europe this summer, and I would doubt doing so hurts the engine.
[snapback]111587[/snapback]
But you don't need to do it.
It's the same with the brake-in rules. You don't need to follow the brake-in rules, and it doesn't hurt the engine. But it's better to do it.
I only use 100 octane gas. It doesn't hurt the engine, maybe it's good for the engine, maybe not. Driving with "usual" premium gas is definately OK too.
If you feel better changing the iol more oftne than the computer tells you, then do it.
#23
Originally Posted by niktee' post='111496' date='Apr 5 2005, 11:09 AM
Go to Auto Zone and purchace (on my 530i it's 7 ) quarts of oil..I use Castrol 0w-30 (made in Germany) and widely assumed to be the factory fill, and go on line and get a good quality filter such as Mann, and you've got maybe 45-50 bucks total. I'm lucky to have an independent who only charges me $10 labor, so in conclusion, around 60 bucks.
I talked to BMW Parts dept. today and they said to get 5W-30?
#24
My Ride: 2006 550i Sport Package, Cold Weather Package, Premium Sound Package, Comfort Access, Xenon Headlights, Adaptive Headlight Control, Navigation System, Steptronic Transmission. Silver Gray Metallic with Gray Leather. Added Red rear reflectors. Swapped stock Style 124 wheels and Bridgestone run-flat tires for BMW Style 125 5-Double Spoke wheels, 8" x 19" front, 9.5" x 19" rear with Michelin Pilot Sport PS2 tires, 245/40YR-19 front and 275/30YR-19 rear.
Originally Posted by uwsc11' post='251173' date='Mar 7 2006, 08:52 AM
What's the difference between 0W-30 and 5W-30?
#25
My Ride: 2013 535i (White with Oyster Interior. Premium Package, Navigation, Technology Pacakge, Park Distance Control, and Rear View Camera)
I was told by a mechanic that BMW's come pre broke in and really don't need a break in oil change, but personally I would not hold much stock in that remark, has anyone else heard that remark before?
I changed my oil at 4000 miles. When I saw the dirty oil drain out of the car, it's money well spend.
#26
Originally Posted by Freewilly' post='251195' date='Mar 7 2006, 09:57 AM
Not ture. Manual clearly said we need to break-in for the first 1200 miles.
#27
My Ride: E61 535d sport, Silver Grey/grey/maple.
20" Hartge Nova 7. Previously 19" staggered 172s
With modern machining tolerances most parts of the engine don't need to be 'broken in'.
The piston rings however do need to bed in or you will get high oil consumption. I know you don't have diesel engines, but they are the worst due to high compression. Synthetic oils are now so good that if you don't let it run to full intervals, for the first change at least, the rings won't bed properly.
After 20 or 30k you can start changing more often if you want to minimise further wear.
#28
My Ride: 2006 530i Sport
Silver Gray - Black Leather - Anthracite Maple
Manual Transmission
Premium Audio
Rear sunshade
Sirius Radio
Autobahnd Roadblock (3M) film kit
Bingo Blingo.
mantraguy
03-09-2015 02:56 AM
Don Juan
03-11-2004 03:14 PM
