Offset Question
My Ride: 2006 BMW 530i
Hi all,
I want to buy a pair of wheels for my 530i and wanted to ask if i might have rubbing issues with the following off set for the front, 19" 20mm offset
the wheels i want to buy are here
http://www.ebay.com/itm/19-M5-Wheels...#ht_5826wt_952
Thank You !!!
Thank You !!!
My Ride: 2006 550i
You didnt specify yr but I think they're all the same. Mine came with 123 18x8 ET 20.
http://realoem.com/bmw/showparts.do?...70&hg=36&fg=15
20mm is stock. if you're upgrading to 19" as long as you use the recommended and appropriate rubber you woint have an issue. For rear is ok I have ET14 on mine and they don't rub although they look like they would. The suspension goes up and in not straight up so its' fine.
its a 2006 530i
Thanks Guys! really appreciate the info!
One more question, so if the offset is 20 in the rear, and i put a 5mm spacer, does that increase the offset to 25, or decrease to 15? i know the wheel will stick out further but how does that effect the offset rating? + or - ?
Thanks
Thanks
BurtonSnol3order
07-03-2015 09:28 PM
