The Official G-Meter Testing Thread
#281
My Ride: 2008 550I,manufactured 2-27-08,delivered 4-2-08.Platinum bronze,natural brown interior,light poplar trim,cold weather package,heated rear seats,HD radio
Originally Posted by Znod' post='249710' date='Mar 4 2006, 11:15 AM
Hi All:
Below are my major unadjusted and weather/altitude-adjusted data from yesterday and today. The beat goes on. I am struggling to lose about .07 in the 1/4. Then, guite a few of my unadjusted passes would start to fall into the 13.5+ category. I have had one unadjusted pass of this level to date--13.564 (i.e., cooler weather).
Unadjusted for Weather and Temperature
.................................5/3.........5/3...........5.4..........5/4
1/4 Speed............103.420...103.520...103.500...103 .240
1/4 Time................13.669....13.713.....13.665... ..13.723
0-60........................5.180......5.248.......5 .192......5.259
1/8 Speed..............82.330....82.200.....82.300.... .82.020
1/8 Time..................8.884......8.929.......8.882 ......8.926
Adjusted for Weather and Temperature
Density Altitude......1765.0...................1722.4
1/4 Speed............105.572...105.674...105.592...105 .327
1/4 Time................13.396.....13.439....13.400... ..13.457
0-60........................4.912......4.955.......4 .916......4.974
1/8 Speed..............83.215.....83.260....83.224.... .83.106
1/8 Time..................8.694......8.724......8.696. ......8.736
The phenomenon of my first pass on a given day being better than my second continues--even though I take a nice slow drive around the countryside between passes. It's hard for me to see that the heat-sink effect is what is causing this pattern. I don't see how I could be causing this systematic "problem." Any thoughts?
I did notice a coincidence.All of your unadjusted times would round up to 13.7 sec.Exactly the time recorded by R & T.The speeds would be 103 or 104,R & T speed was 104.The do not use corrections.I doubt that R & T's conditions would be as unfavorable as yours.All this means is that you are getting signicantly better times than R & T.
#282
Originally Posted by grogan545' post='249913' date='Mar 4 2006, 08:03 PM
Sorry Znod I had a typo for dew point.It should have been 5 F.I have tried a few more 1/8 runs with temp at 32 F,Dew point at 18 F,barometer at 30.18.I am not going to bother posting all the numbers,but I had all 0-60 numbers in the 4.80's and 1/8 times all in the lower 8.60's with speeds all more than 83 mph.I am confident that I can repeat these numbers consistantly in this weather.I will wait for 60 degree weather to see if I can get similar numbers.When I first started testing in May of 05 I had a run of 4.85 in 60 degree weather.I discounted it because I could never repeat it.Everything was new to me at that time so I have no written documentation.However I do remember forgetting to turn controls off on some runs.I have no recollection if that was the case on this run,but the data I am getting now leads me to believe that it is possible.As soon as conditions are close to "standard" I will run more tests and post data.
All of what you say above sounds very good. And, it will be very interesting to see your near standards results. I think that doing so is a great idea. I will be getting nearer and nearer to standards as spring approaches, but, of course, there is no way for me to lower my altitude--except through the NHRA adjustments. As you know, I have been paying some weather "penalties" too.
I am working on a very complicated analysis that implies, as you have suggested, that our optimal shift points might be less than approximately 6.45k. Right now it looks like approximately 6.4k would be better. The analysis, which is based on the Pro RR's "real" road-torque values, is too time consuming and too complicated to try other shift points--which might be even better. And, another reason for not doing but one analysis is that our hands are tied for now anyway--i.e., we can't make the Step shift earlier than it wants. BMW hasn't provide us with the opportunity to apply good old yankee (drag-racer) ingenuity. Darn!!! The new analysis will contradict the more conventional analyses that I posted on the other thread that deal only with a dyno-produced 545i torque curve.
#283
Originally Posted by grogan545' post='249915' date='Mar 4 2006, 08:19 PM
No ideas yet on why your first run is always the best.I really didn't take note if this true for me.I will pay closer attention to see if it is the same for me.
I am taking the Z06 out for a couple of 1/8's in the morning. I'll sneak my results into this post.
They are below. Good passes, but too much wheel spin on each pass. My 60' times definitely were too high (2.004 and 2.015). I can do better. There is room for much improvement (i.e., best 0-60 .377 earlier). Note that my best 0 to 60 below is too slow by about the amount that my 60' times are off given prior knowledge of Z06's.
Unadjusted
.......................Pass 1........Pass 2
0-10.................0.351.........0.364
0-20.................0.945.........1.025
0-30.................1.638.........1.611
0-40.................2.298.........2.242
0-50.................3.334.........3.236
0-60.................4.021.........3.961
0-70.................4.999.........5.294
0-80.................6.249.........6.300
0-90.................7.495.........7.573
0-100...............8.913.........9.013 (9.013 - 8.913 = .1)*
0-110...............................11.040
0-112.39............................11.51 (1187.72')
1/8 Speed........93.92...........93.4
1/8 Time...........8.022.........8.027
1/4 Speed.........................105.3 (coasted from 1187.72'--see above)
1/4 Time............................12.33 @ 105.93 (12.23 if I allow for *)
1/4 Spd (est)....................116.00 (average of US mags. with passes similar to mine)
1/4 Time (est)....................12.30** (12.20 if I allow for *)
*Note that Pass 1 would have yielded a better 1/4 time & 1/4 speed by about .1 sec & .52 MPH.
**11.51 + {60 sec [(1320' - 1187.72') / 5280'] [60 MPH / (116 + 112.39) / 2)]
Adjusted for Altitude and Weather
1/4 Speed..........................106.9
1/4 Time..........................12.145 @ 106.9 (best weather-adjusted mag time = 12.40)
1/4 Speed (est)................117.80 (based on 116 value above)
1/4 Time (est)..................12.115 (based on 12.30 value above)
Assuming .1 sec and .52 MPH better result in 1/4 based on **--results of 116.52 and 12.199
1/4 Speed (est)..............118.329 (based on 116 value + .52* = 116.52)
1/4 Time (est)..................12.017 (based on 12.30 - .1* = 12.20)
I keep trying to find a way to get to less than 12.0. I am kicking myself because I easily could have had a 60' foot times that would have gotten me below 12.0 at least on an adjusted basis given the following results of my earlier 0 to 60 in 3.77 pass. Darn.
0-60 3.77
0-50 3.03
0-40 2.08
0-30 1.45
0-20 .88
0-10 .25
60' 1.88
330' 5.15
Done deal: Went out this morn.; one pass; less wheel spin; went home; and happy I am. Briefly,
............................Unadjusted.......Adjus ted
60'............................1.902
0 to 60......................3.893
1/8 Speed................94.012
1/8 Time....................7.936
1/4 Speed................116.45...........118.747
1/4 Time..................12.165..............11.935
#284
Originally Posted by Bokke' post='249574' date='Mar 3 2006, 11:06 PM
Get lost.....
I find it interesting that you don't have the BALLS to post your location in your avatar....
I think you were just clocked doing 22 in a 20mph zone....throw that book at him....
looser...
I am surprised it took this long to get this kind of post.
Hey FastCarFan I come to a complete stop on the freeway, set the meter and then launch to 155mph.....get a life
looser...
#285
Originally Posted by BetterMakeWay' post='250173' date='Mar 5 2006, 12:45 PM
Ahahaha...again...i somehow agree. Not with the tone or the insults but i kinda agree. We'll have to really be ponderate. Not drive like lunatics, or ticking bombs, but not like 100% law respecting squat. Also i do bealive we would better start DRIVING our cars then minding with those geekish stuff. Don't want anyone to be offended by my reply.
#286
#287
On the "I agree part," I am curious about which part(s) of the above quote you specifically agree with. I have no problem with you agreeing with anything you want, but I am curious because you are agreeing with someone who apparently showed up for only one day simply to cause trouble, made veiled threats, did not post his or her location, and did not indicate if he or she even owns a car.
#288
I understand (in a way) that this stuff is important to you but i don't see it that important, only a waste of time and brains. I've seen F1 sites and docs with less data and...well....rubish if u ask me. That's too much geek stuff. Bmw if you look at it should mean a car to drive. I don't agree with the fact that it's a waste of bandwith, after all everyone is free to say whatever he/she wants. Especially if no one gets insultes or stuff like that.
Having clarified that, i assume this will be my last vizit here since i walked in just out of curiousity because i knew from the very begining what this thread is all about and as i found it uninteresting i didn't bother. But when i saw how huge and big it became i had to have a look (18pages? wow!). Now 20 and i don't see the point of it. No problem by me. I just said that if you by any chance wondered why did i post if i found it boring.
#289
Originally Posted by BetterMakeWay' post='250223' date='Mar 5 2006, 02:59 PM
Sorry man but i agree with the fact that you somehow try to keep this thread alive, sometimes posting almost all by yourself.You're sometimes a bit weird. Not by this thread alone but you express yourself in some replys in a way that makes my head go boom. Don't get me wrong i like cultivated speech but when this is not needed why use it? The same thing could be said in easier words.
#290
My Ride: E60 M5, F85 X5M
Come on guys. Everyone's entitled to their own opinions but seriously, if you don't have anything nice to say, don't say it at all. This forum has been awesome predominantly from the many positive contributions by members. Let's refrain from saying anything negative if it's not called for.
Hope we're in agreement with this. Peace!
