oem battery
my 2004 bmw battery died on me awhile back, and i replaced it with an aftermarket battery that fits the car just right.. it worked really well 4 the first month but soon after i started getting weird codes that came and went. ( like alternator code, and active steering. and car would not start right up alot after that month) does anyone know if it can be the after market battery?
u need to program ur battery at the dealer.
https://5series.net/forums/topic/113...2#entry1343562
dont want to say i told u so to all the people in my thread but.... TOLD YA LOL
u will down the road. some say they dont have any issues but others do... for instance my steering wheel tightened up and felt like i lost power steering until i had my battery programed. hope u dont get any issues though..
Most likely the IBS sensor has failed. It prevents a full charge from ever being achieved by the charging system. Don't worry about the 'battery' coding - look at the IBS sensor.
You can test it by simply disconnecting one wire - it will take the IBS offline and thus normal charging will occur.
Also if you are not driving long enough (what BMWNA calls an unfavourable driving profile) the charging system simply can't re-coup the starter loss.
If you have active steering there is a greater chance that it simply wasn't calibrated - has NOTHING to do with "battery coding."
socale39
09-05-2023 08:30 AM
kane1111
04-10-2015 04:40 PM
