Is this Normal?!?
My Ride: 04 545i Sapphire black
-18' M5 wheels
-Sport pack
-LED Angel's
Alright, I have an 04 545i sport pack and I noticed that the car has a very slight shake to it when it is idling. When you rev it slightly it shakes when the idles come back down. Is this normal for the N62 engine? The rpm sits at 500 which seems a little low to me.
My Ride: 2006 BMW 550i
eh, sounds normal for the most part. you could do some basic maintenance to see if you can help smooth it out. clean maf sesnor, change plugs, add some fuel injector cleaner, etc.
500 is normal.
500 is normal.
-18' M5 wheels
-Sport pack
-LED Angel's
alright replaced the plugs with ngk iridiums, and Achtung, I appologize for being rude to you in that other post. You really think motor mounts, cause this? Wouldn't I feel it when I switch reverse to drive?
My Ride: 2012 535i X-driveSpace Grey/Black Dakota, Fineline Anthracite Trim; Executive Package (Rear View, Lumbar, Nav, Voice, SIRIUS, HiFi Pro) Technology Package (Hi Beam Assist, Lane Departure, Blind Spot Detection, Surround View) BMW Apps (Apps, Smart Pho
Model Year: 2012
Not sure about BMW mounts but two of my retired MBs needed new motor mounts. The very slight shake was usually noticeable in either D or R since the engine shifts slightly depending on which forward or reverse gear you are in. The older the car or a high mileage car can develop worn or cracked mounts as the mount material dries out (believe it is rubber but not sure).
BTW, my retired E60 idled in the 600 rpm range.
My Ride: 2014 535 Alpine White
I get the same thing the OP stated but its not bad, i feel a slight shake when the car is idling, i willhave my mounts checked out but im not going to do anything unless it gets worst. I have a 6 speed, it maybe just me being anal, when i rev the engine the car rocks a little but isnt that the beast coming out? LOL
Model Year: 2012
Yes of course motor mounts cause this. But since you changed nothing but the spark plugs it could be a an idling issue did you do anything else with the valve cover or anything that may have caused a vacuum leak?
