noise in steering
#31
funny.
i have it too.
it sounds like some sort of harmonic groan at slow speeds, tight turns (ie u-turn) etc. yesterday,i just kept driving around in a circle until my wife told me she was going to be sick.
dealer checked it out, coudnt duplicate.
i have it too.
#32
My Ride: 2006 BMW 550i
do you have the active roll system?
i get the same groan/whine. its louder if i turn harder. and changes in pitch as i rev the engine. no noise when turning when parked though.
#33
i have the same groan. it's usually slow speed turns into a parking spot or when i start a turn at an intersection. it's been mostly happening when i turn left. dealer was able to replicate, but they said it was coming from my "low profile aftermarket 20" tires" which i don't think is the case. maybe maybe not. haven't had a chance to put the stocks back on and see if it happens. hope someone figures out a definitive answer, it's a pain to hear....
#34
do you have the active roll bar system?
#35
dc
#36
My Ride: E60 530D
Probably this is the best description for my steering noise. In my opinion could be the power steering pump (I've added Lubrizol 6178 additive with no results). Are there any new solutions for this?
#37
I have the same groan/moan at low speed, tight turns. I also have ARS and Active Steering. The dealer told me it's normal with cars that have AS. Until it breaks, I can't do anything about it, I can live with the noise. Now if only I can get the windshield whistle fixed
#38
I have the same groan/moan at low speed, tight turns. I also have ARS and Active Steering. The dealer told me it's normal with cars that have AS. Until it breaks, I can't do anything about it, I can live with the noise. Now if only I can get the windshield whistle fixed ![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
Good luck, I still can't locate mine! I've pressed on every spot and there is never a change...
Vman33
03-14-2022 04:43 AM
