Noise coming from engine bay. Please see video
Old 08-30-2013, 05:00 PM
7_rocket's Avatar
My Ride: 2004 545 6 speed
Originally Posted by TU2TLE
is your fluid bubbly?
Nope, but I'm going to change it anyways. I'm planning on doing all fluids, already done the oil.
Old 08-30-2013, 05:23 PM
TU2TLE's Avatar
My Ride: Silver 550i: Orion V2 - LCI Tail Lights - VRM 710 (Powder Coated Matt Black) - Magnaflow Cat Back Exhaust - Painted Brake Calipers (Red) - Painted Rear MTEC Kit (Black) - Window Tint (Windshield 70% - All other Windows 55% - Smoked Side Markers
well I know you don't want to probably hear this, but it sounds like it's your active steering. Your active steering is a part of your sway bar. To replace it you're going to have to replace the whole thing. Sway bar and motor itself is more than likely what your issue is and your motor is on its way out. The only way to to be for sure if it is what it is, is if you have another active steering malfunction. So this is where you play the waiting game. Good luck
Old 08-30-2013, 05:31 PM
7_rocket's Avatar
Thanks for your help. I"ll get it checked out by a Indy asap.
Old 08-30-2013, 05:38 PM
TU2TLE's Avatar
if you're going to go to an independent shop make sure they're going to give you a free diagnosis. The reason is there is no code right now that's being presented on your computer, the good news is it's more than likely saved in the memory of your previous codes. But you don't want to waste a hundred bucks to diagnose your car when there's no codes. Take it in hopefully the code is still there and they will tell you as much as they can, good luck. let me know what happens.
Old 08-30-2013, 05:41 PM
7_rocket's Avatar
You know you're right. My buddy has a ODB or whatever it's called and he plugged it in but didn't show any codes. I was planning on putting the car on jack stands to see what exactly was happening, man I hope you're wrong as I just bought this car not even two months in.
Old 08-30-2013, 05:43 PM
TU2TLE's Avatar
here is the part you're going to need. The luxury of the owning at BMW.
BMW E60/E61 5-Series Sway Bar / Active Stabilizer OEM
Old 08-30-2013, 05:45 PM
TU2TLE's Avatar
well you have another option. You don't have to purchase the active stabilizer bar. H&R makes one for about 300 bucks. You lose active steering but its up to you if you want to spend an extra thousand or 1100 dollars on the active steering bar.I have active steering as well and I'm going to dread the day that my goes out.
navisingh
04-18-2015 02:20 PM
derooster
04-16-2015 05:53 PM
Guitarjon
04-11-2015 04:24 AM
Karlosfandango
03-10-2015 09:48 AM
08-12-2003 11:41 AM
Quick Reply: Noise coming from engine bay. Please see video
