No start in the morning
Old Apr 5, 2026 | 08:37 AM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Default No start in the morning
I tried to start my 2004 530i in the morning to go to work but nothing happened. No crank, all dash light were fine (not dim).
What could be the issue, battery or starter or something else ?
Thanks,
Ching-Ho Cheng
Old Apr 5, 2026 | 10:02 AM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Sounds like a starter issue from your description.
Old Apr 5, 2026 | 12:51 PM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Could also be the ground strap.
Old Apr 5, 2026 | 02:58 PM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Thank you. Could the car scanner identify starter issue ?
Old Apr 5, 2026 | 03:00 PM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Thank you where is the ground strap located ?
Old Apr 5, 2026 | 09:16 PM
twh's Avatar
twh
Engine: N52
watch this video...
Old Apr 6, 2026 | 01:57 AM
donpb's Avatar
My Ride: '06 530i N52
It could be a lot of things.
  1. If you hear a click clinking, it's most likely a bad starter.
  2. What codes did you read?
  3. What battery tests did you perform?
    1. Battery charge status?
    2. Load test?
    3. Charge status histogram?
  4. Did you try disconnecting the IBS?
  5. Does it eventually start after the morning?
aw3964
Feb 10, 2021 10:39 AM
Enrique.79
Dec 18, 2018 05:46 AM
selbycy
Nov 2, 2010 12:58 PM
JRD_530i
Jun 6, 2010 11:32 AM
jreezye60
Jan 14, 2010 11:38 AM
