No Power to Driver side door??
Has any one had an issue where there was no power to their door? My driver side has no power,the lights/windor/switch etc does not work. I checked the fuse and its fine (swapped it for the passanger side and it works).
Are there anything I should check before I open the door panel? relay switch, etc?
545i
thx
545i
thx
I had that problem and it was my fuse in the glove box. Replaced it and all was ok... Are you sure you had the right fuse?
Well based on the fuse map for the glove box, it should be right. I pulled the one for the passenger door and it went dead so I put the one that should be for the driver side into the slot for the passenger and it worked. So "that" fuse is good. I swap the fuses and still nothing. I get my 5-series Bentley manual in a few days....so I maybe able to pin point the power issue without having to take the panel off.
