Need Help to Solve Brake Issue
I have a 2006 530xi and I have a problem with my brakes I just can't figure out.
Symptoms:
Long Brake Pedal Travel - Basically goes all the way to the floor
High effort to slow down the car
Doesn't feel firm
What I tried to fix it:
Replaced master cylinder
Flushed the fluid using Motiv bleeder and super blue fluid.
Could there be air in the abs unit? Is there a way to cycle it without using a DIS that can be done on other models. I have DTC but I don't think I have DSC. The brake booster tests you can do with the pedal and turning the car on and off seem to show that it is working find but the pedal is pretty much to the floor when i do it. Any ideas?
Symptoms:
Doesn't feel firm
My Ride: 535i M Sport
Model Year: 2010
Symptoms:
Doesn't feel firm
Symptoms:
Doesn't feel firm
High effort to stop is often a faulty brake vacuum booster. Basically, the car is behaving like an old time car without power brakes.
So, you should check the vacuum lines to the brake booster.
Also, the N52 has an auxiliary vacuum pump rather than taking the vacuum from the intake manifold. The Bentley manual says it is located front lower left of the engine and is driven off the oil pump chain.
Check that also to make sure the vacuum hoses are hooked up and check for a vacuum.
UltimatePeter
DIY: Do It Yourself
09-28-2015 09:12 AM
