Need help with Satellite radio.
My Ride: '06 550i - Auto
I have the Satellite radio module in the trunk, but there's no option to select it on my CCC. I'd like to get a subscription to Sirius if I can figure this out. Thanks
My Ride: 530i
Engine: M54
you need to check your VO and CCC coding to make sure the car is programmed properly to recognize the Sirius module. There are several threads out there detailing how to do this. good luck.
Thanks, but as usual I seem to be screwed until I can get INPA working on my laptop. Maybe next time you're in Nashville, you can stop by and give me a hand with getting it to work.
My Ride: BMW 530xiT (E61)
hate to state the obvious here, but have you tried unplugging the MOST connection and antenna cable and plugging them back in? I had to disconnect my SAT receiver to service the hydraulic pump for the liftgate (i have an E61) and it disappeared from the CCC, but when I plugged it back in, it re-appeared.
if that doesnt work, I think KyleB's advice is spot on - make sure it's actually coded to the car.
With a VIN decoding, you could see if car originally had SAT when it lift assembly line.
https://www.bmwvin.com
Does S693 mean my car came OEM with everything needed to run satellite radio? If my car is S693, does that mean a simple CCC recode will give me satellite radio?
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
It means your car was cabled for a future install of the module. All you should have to do is get it coded at this point since you have the module. "Preparation" means that the cables have been ran.
