Need help with Satellite radio.
3 Attachment(s)
I have the Satellite radio module in the trunk, but there's no option to select it on my CCC. I'd like to get a subscription to Sirius if I can figure this out. Thanks
did you install it or was it there when you bought the car?
It was there when I bought the car.
you need to check your VO and CCC coding to make sure the car is programmed properly to recognize the Sirius module. There are several threads out there detailing how to do this. good luck.
Originally Posted by KyleB
(Post 1590396)
hate to state the obvious here, but have you tried unplugging the MOST connection and antenna cable and plugging them back in? I had to disconnect my SAT receiver to service the hydraulic pump for the liftgate (i have an E61) and it disappeared from the CCC, but when I plugged it back in, it re-appeared.
if that doesnt work, I think KyleB's advice is spot on - make sure it's actually coded to the car. |
With a VIN decoding, you could see if car originally had SAT when it lift assembly line.
https://www.bmwvin.com |
Originally Posted by BostonJon
(Post 1590400)
Originally Posted by jtbgonesailing
(Post 1590403)
https://www.bmwvin.com Does S693 mean my car came OEM with everything needed to run satellite radio? If my car is S693, does that mean a simple CCC recode will give me satellite radio? |
It means your car was cabled for a future install of the module. All you should have to do is get it coded at this point since you have the module. "Preparation" means that the cables have been ran.
(Post 1590419)
