Need Help replacing supporting mirrors ring
1. Tilt the glass all the way up, insert a popsicle or some sort of stiff plastic stick under the glass and "pop" it off
2. Release the plastic tabs and push forward to remove the front cover
3. You should now be able to remove the supporting ring but it might be easier if you take out the 4 torx screws to loosen the inside plastic housing
4. The supporting ring just clicks into place so you should be able to remove it by carefully prying it off the tabs
TexaZ3
05-06-2015 09:54 AM
